Samsung LN46C800 No Backlight
  • Ltank
    • Jun 2013
    • 776
    The power supply turns on. I reviewed the threads to the other Samsung set that used the same BN44-00341B Power Supply. I did download the power supply schematic. This set has sound and Picture if you hold a flashlight to the screen. The correct votages are on CN802 from the mainboard and
    CN1802 to the backlight board. There is no H.V. off CN1801 to the back light board. I do have 380 vdc to caps CP802 and CP803. I checked the diodes and transistors in that area. The HV transfoemers checked good with a Blue Ring Tester.
    I did not check ICM801 or any of the SMD parts on the foil side. I did find any shorts to ground on the inverter board and ttried the P.S. without the inverter as a load and there was not any voltage on CN1801 to thge inverter.
    Is it ok to run these without a load? I even jumped the 5vc to the Ps-on.
    pins 17 to 18. any thoughts anyone? I guess I need to put P.S. Booard in holder and put jumpers on CNCN802 . I jumped 5vdc to Ps-on and to SW_inv to turn on the inverter power. it measured 5vdc when connected to main board. Does it need to go low to turn on the HV inverter?
    Re: Samsung LN46C800 No Backlight
    This power supply-inverter combo board has built-in pull-up resistors, so when you disconnect the cables between the power supply board and the main board, the backlights should comec on right away the minute you apply 120VAC to the TV, no need to use resistor to force on the board.
    Did you check CI818 (0.47Uf 450VDC) cap? That is one commonly failed cap, check its value.
    What do you have on LD?
    • Ltank
      • Jun 2013
      • 776
      I did remove the cable from the main board to the power supply and the backlight did not turn on and there was 0vdc on the pins to the inverter board. I will check that capacitor Monday when back at the shop. Thanks
      • Ltank
        • Jun 2013
        • 776
        I replaced the C1818 .47uf 450v and the backlight came on. Works fine!
        Thank you Budm
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ermals
          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
          by ermals
          Hi all!
          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
          3. I've checked voltages...
          08-01-2022, 10:35 AM
        • lostone
          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
          by lostone
          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
          05-19-2024, 11:40 AM
