RCA L42FHD37YX8 Poer button not working
  • Snype32
    • Jun 2011
    • 76
    I have a RCA L42FHD37YX8 that I have been working on. It is now to the point where if it is plugged in, it turns on right away. All the buttons work, and I can turn it off with the power button, but not back on. When using a remote, the green led flashes on the tv, but it will not turn on. Again if I unplug it, plug it back in, the remote will turn the tv off, but not back on. There is a reset button on the main board that if pressed will turn the tv on. Any ideas what I should look for? Thanks!
  • Zippo978
    PS4 Fat, power button not working
    by Zippo978
    I have a first-model PS4 Fat with a touch power button. Now the button isn't working, and I don't know why. How can I fix it? And if it can't be fixed, is there a way to bypass this button and install a "normal" button?
    10-02-2025, 04:42 AM
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • myth77
    Asus Gl753, gl553, fx553 keyboard power button not working
    by myth77
    I have i think 4 dead keyboards from laptops in the title...they are very similar...almost the same...and all of them have not working power buttons. All other keys are working...but when you press power button it doesnt short 3.3v to gnd...so you can only do it manually on the keyboard conector with tweezers or similar. I inspected in every detail ribbon cable that is going to the motherboard connector and removed power key button from keyboard to see anything wrong there, but all seems perfect.
    Has anyone with more expirience figured where is that power button line getting broken? because...
    07-13-2023, 12:30 PM
  • Scoff
    LG55UB850V no picture or audio - flashing LED's help please?
    by Scoff
    Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
    I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
    We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
    01-26-2022, 06:13 AM
  • modtool
    HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
    by modtool
    Dear colleagues,
    I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
    The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
    Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
    05-07-2025, 06:10 AM
