Panasonic TH50PX600U Plasma - no picture/OSD
    Done a lot of work so far but stumped a bit. At first I had 20 LED blinks and no picture, which according to Page 6 of this diagnostic guide:
    is a communications error. I bought and replaced the DG and D board. Now no more LED blinks, but still no picture and no OSD. Followed the procedure on Page 32 and Page 38 (I get a white screen when unplugging DG5), and the LEDs on SC and SS are lit, which indicates DG or D board (which I replaced).
    Any ideas?
    Re: Panasonic TH50PX600U Plasma - no picture/OSD
    Are the new boards the same revision as your? Does it power on normal now and the SC,SS leds lit?
    Possibly try reseating the LVDS cable at both the D board and the DG board. I think maybe D5-DG25.
    I had a SD PV60 which had a black screen but powered normal. Very bad LVDS cable, suspect dirty contacts, had to reseat several times before I made any progress.
    Before I did that, I turned the TV on , Tv mode, disconnected antenna lead and plugged the video out from the back of the TV to the av input of another and I got the no signal banner displayed on the monitoring TV.
    Proved to me there was hope my TV main board was ok and made me take a shot at the LVDS.
    This may not be your issue , just some ideas to try.
    If the set is not turning on at all and no SC,SS leds then what I mentioned above won't apply.
      Thanks - I will check cables and revisions. I also want to test an A/V input to see if I have sound but I bet I do.
      Yes, after replacing D board, it no longer error blinks, and it does power on OK with a glow. The LEDs on SS and SC are lit. Removing DG5 gives a white screen, that indicates D board, maybe it is bad rev or bad board ;-(
        Full white is GOOD for D board and indicates panel is fine. DG or H likely cause.
          So being that I already replaced the DG and D board, that would leave the H board as most likely suspect? I tested yesterday and I don't think there is NO sound either (hard to test without picture ;-()), if that helps.
          So it looks like:
          - H board
          - cables need to reseated
          Make sense?
          Thanks for help.
            Ah ha - well I replaced the DG board and D board.
            Turns out I replace the DG with the wrong version number - I used TNPA3903BCS rather than TNPA3903BFS. I suppose this is my problem since the price and availability is very different ;-)
