Sony KDL-46NX810 – 6 blinks and digital channels disappear
  • srednausab
    • Nov 2013
    I bought this TV set refurbished in August 2012, at a Sony Outlet store.
    I have a couple of problems:
    1. Occasionally the backlight goes out occurs, picture does not appear but sound does. Shortly after that, the TV goes into standby mode and then get the 6 blink standby light diagnostic. If I remove power from the set and let it sit for a while (say one day) and then power it back on, then chances are good that it will start properly and I'll have a picture again.
      When I power on the set in self-diagnostic mode (DISPLAY,5, VOL -, Power), the backlight error count goes up by one.
    2. After the set has been turned off and then on again, the settings for TV source (reverts back to “Antenna” from “Cable”) and the channels will have disappeared (so I have to go through the setup again [30+ minutes] to pick up all the digital channels my cable company provides)
    The main annoyance is with the first problem as it is intermittent
    I haven't changed the main board yet, though I suspect that it's going to be the first thing that I'll do, as I don't think that the backlight is really at fault.
    I do have the service manual for this TV and am busily poring over the schematics even though I'm not that familiar with electronics (though I do know what a capacitor is, and what it does…)
    Anyone out there have any ideas how I can solve these “glitches”?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46NX810 – 6 blinks and digital channels disappear
    I have repaired a KDL46NX720 recently(I have it in my livingroom=~$200 with new pair of glasses ). It had most likely a different issue then yours.
    Mine turned on normally and after showing the image and sound it would turn off and blink a 4 error code.
    My problem it was the LED driver board, right in the center of the TV.
    On my board, I had some check points at each IC. I have measured at each that voltage and and at one of them I had a different voltage then at the rest of them.
    After opening the panel, I have noticed that the last 16 LEDs at the bottom and at the top would turn on initially and then they would turn off. By replacing that board, fixed my TV.
    You could check those test point if you have them, to see if you are getting different numbers. I think, if they are all the same, then you may have a different issue and not LED and LED driver issue.
    • srednausab
      • Nov 2013
      Thanks for the info...I'll have a look at the schematics..presumably test points will be marked.
      • tibimakai
        • Jan 2012
        • 3680
        This is the board that I had in mine. I have circled those test points:
        • srednausab
          • Nov 2013
          Well, at last I got around to sorting this issue and bought the replacement backlight inverter board for about $20 (American) and replaced the board in the TV.
          Lo! and behold! it worked. So far (and I'm keeping my fingers crossed) the TV has beenhttps://www.badcaps.net/forum/images/smilies/dancingsmilies.gif working well with no blink codes and no disappearing screen.
          • UserXP
            Vintage SONY Digital Clock Radio ICF-C12W no audio
            by UserXP
            Dear all,
            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
            My question is, do you know of this brand of capacitors and how bad are...
            07-21-2025, 08:35 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:27 AM
          • Xristakis795
            le32a436t1d problem with digital channels
            by Xristakis795
            hi to all
            I have the above TV and it presents the following problem
            when i tune in and search for terrestrial digital channels he finds them normally
            but I hear only sound I do not see image and I have to see with mpeg4 decoder external device
            what could be wrong?
            12-31-2021, 05:55 AM
