Panasonic Viera TX-P50U20B startup problems
  • shimmyshimmy
    • Nov 2013
    • 4
    I recently bought this TV on ebay fairly cheap hoping to be able to repair and use it. The problem is that when the TV is turned on with the main switch I just have a green light and a clicking relay, it clicks 4 times over and over for around a minute then stops. There are no flashing red lights and when I press buttons on the remote the green light flashes as if it is responding to the input. I have tried connecting a source to check for sound but I can hear nothing.
    I found a cheap power supply online so decided to try this hoping it would solve the problem, however I have exactly the same symptoms with the replacement supply. I would really appreciate ideas as to my next step, possibly I should test the X sustain and z sustain? Both boards have an LED which is lit does this mean they are working ok? I have some experience testing things with a multimeter so would be fairly confident having a go at troubleshooting this.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Viera TX-P50U20B startup problems
    Probably need clarification on the startup. So for your model is the normal sequence this.
    Power available /standby- solid red LED
    Startup - rapid flashing green LED
    On - solid green LED
    So are you saying it tries to startup, green LED just continuously rapidly blinks and the relays just keep cycling, quits after a minute?
    What then, solid green LED, no display or goes back to solid red , standby or does it blink out the red LED a fault code?
    Sounding like A-board at this stage.
    • shimmyshimmy
      • Nov 2013
      • 4
      There is no red LED on standby just a green light on startup which flashes rapidly for a few seconds then turns to solid green. As I bought the TV in this state I'm not sure if I should have the red LED on standby or not.
      When the relay clicking stops the green LED stays solid, and it only flashes when I press buttons on the remote. Is there a way I can test the A board?
      • tw2005
        • Oct 2011
        • 6458
        Yeah, I'm a little lost with noe red standby led but I don't know the UK market. so goes solid green, blinks with the remote, and at this stage are both sustain boards status LEDs lit?, so the panel should be energised.?
        Can you see if the panel has a faint glow?, may need a dark room to really notice.
        If the TV has been used before, if you hook up the antenna and select Tv and flick though the channels, any audio?
        • shimmyshimmy
          • Nov 2013
          • 4
          I was expecting to see a red light on standby but there is nothing until it is switched on. I can see 2 green LEDs presumably the sustains either side of the tv but this is looking with the back cover still on...I will check with the back off ASAP.
          There is definitely no glow from the screen even in a dark room.
          I have hooked up my xbox to check for sound but wasn't 100% if I was flicking through the sources with the remote or not. I will connect an aerial to check the built in tuner.
          This isn't turning out to be as easy as I'd hoped!
          • tw2005
            • Oct 2011
            • 6458
            I have 2 thoughts, bad A-board or cracked panel. I have another idea for the A-board.
            I thought if the panel was cracked it would shutdown with sos7 or something but maybe they don't always and might depend on whether the panel is shorted.
            Never had this situation before to know, maybe someone else can clarify.
            usually there's a video out signal on the a-board. you could hook that up to another TV on av in, select TV on the broken TV, leave the antenna out and the display would normally show a banner regarding no signal.
            This should then show up on the other TV through whatever AV in you used. I've done this on an old 2006 panasonic plasma with nil display but appeared to turn on and it output that display.
            That was a bad LVDS cable which your Tv won't have but proved the mainboard was working at least. worth a go I guess.
              A cracked panel would normally lead to the MID voltage falling due to changes in panel resonance. This would cause LEDs to go out.
              • tw2005
                • Oct 2011
                • 6458
                it's a strange one, have you struck anything like this? Would you expect with both sustains on, surely some signs of the panel being on. Weird?
                  The 2011 series Panasonic have very deep black levels. It's also possible the A board goes into dynamic/vivid mode with no input, which can sustain the panel but cut black down to <0.001cd/m^2 (pretty much invisible) on scenes where there is only black or dim pixels, MID voltage will still be there, it only sustains the 1SF (LSB of image.)
                  • mostachio
                    Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                    by mostachio
                    Hi Badcaps,
                    I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                    TV Details:
                    Model # - TH-65DX700Z
                    Symptoms:
                    The television turns on and displays a picture then makes a clicking sound and turns off.
                    I haven't opened it up yet but...
                    09-04-2024, 02:32 AM
                  • Ama Chur
                    Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                    by Ama Chur
                    After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                    02-21-2025, 08:12 PM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    Yesterday, 06:40 PM
                  • badcappo
                    Dead Panasonic Viera TX-P65STW50 Plasma TV
                    by badcappo
                    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                    Diode type G972s6 - D101 with a short
                    Mosfet 06N90E - Q301 shorted
                    Fuse T5AH 250V - F103 blown
                    Diode D301 shorted
                    Relay DG1U-17VDC II - RL001 blown
                    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                    11-24-2024, 11:27 AM
                  • J8rda7
                    Panasonic Viera TX-L50E6E - no image
                    by J8rda7
                    the TV has a black screen. Sound OK, backlight OK.
                    When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
                    I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
                    Thanks to anyone who can guide me in solving the problem.. and be patient with my english 🙂😁
                    05-13-2024, 11:04 PM
