Can it only be done with the help of the service manual for that specific tv or are there generic guidelines that will work ?
How Can I Verify Existence of Video Signal with a Scope ?
Re: How Can I Verify Existence of Video Signal with a Scope ?
Imagine the Oscilloscope as to be a spoon, and the video signal as to be the sea.
What you can do with the spoon is to taste the water so to examine the saltines.
If you need to sea a picture of the sea waves, what you need to have is a digital monitor and not a spoon. -
^I'm not sure what that analogy is supposed to mean, but please remember that analog video signals have been analysed with analog oscilloscopes and vectorscopes for years prior. Budget digital scopes are worse than analog scopes for video analysis. You need to spend a lot of money to get a decent digital scope for video analysis.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I just acquired an old analog scope (iwatsu ss-5711) and will be learning how to use it as I go along.
I have a tv that has no video/osd but good back light and had a suspect tcon which I replaced twice (thinking the first was faulty) but am doubtful now. Would like to simply see evidence of signal coming from Mainboard into T-Con before I make my next move.Comment
What is the panel model number? look for it on the sticker, then look up the spec sheet to get the pin out of the 6 LVDS/or 5 depends on the LCD format (Channel A~E, plus Clock), the LVDS is conformed to EIA664, eash signal is terminated with 100 Ohms on the receiver side.
You can look for activity, dead main board will show no activity. signal is less than 2V.
To have all dead signals (no output) from all 6 or 5 outputs will have to be something that is common to ALL the signals that failed such as no B+ to the driver ICs.
You are using the scope to look for signal present, for analyzing the waveform to see eye pattern, you will need better scope. I use TEKTRONIX 2210 for checking signal present only.
Example:
https://cdn.badcaps-static.com/pdfs/...8254cd7cb6.pdfLast edited by budm; 11-05-2013, 11:10 PM.Never stop learning
Probably 4 data plus differential clock.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Do you have proper voltage at both ends of the tcon fuse? No voltage, no picture.
There should be either 12V or 5V at the fuse. Need a picture of the TCON, Main, power, and a general picture showing the back of the tv,(cover off please).Comment
1 pair of data line (+/- diff signal, it is basically balanced signal lines), so you you have 4 pairs of data line and 1 pair of clock.Never stop learning
There is A0-A4 (+/-) and B0-B4 (+/-) plus two differential clocks.
@truep, yes I tested for voltage on both sides of the fuse and it was there. I think it was 12v but that was some time ago.
I've found a few shorted capacitors on the mainboard and removed them but that circuit is still shorted. Perhaps this could be the root cause ?
I will attach a few pics and maybe I could get some input on what to check for.Comment
As you can see, there will be small value (<1uF) SMD MLCC in parallel with the electrolytic cap. I.E. C817 is in parallel with C816. MLCC when it failed, it shorted out. You can also have shorted load.
What TV is this you are working on?Never stop learning
Oh happy daysI've found a schematic that fits what I'm seeing on board. Both are part of 3.3v regulator circuits - one for BCM and the other for TMDS_SW for whatever that's worth. When regulators fail do they often short out ? These are listed as AZ1117H.
MLCC: Multi Layer Ceramic Capacitor.
Regulator can have failed Output shorted to Ground, input shorted to ground, Input to Output shorted. You can remove it to find out.Never stop learning
Well I was busy patting myself on the back after removing the two regulators and the short still exists.
After removal one shows the center pad grounded and on the other the tab pad is grounded.
I have now officially managed to confuse myself further haha.
At this point I would *guess* the short lies further up where the 3.3v sources are attatched.
What do the trained eyes here see ?Comment
This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...09-12-2024, 02:00 PM
Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...11-23-2023, 11:02 PM -
by sam_sam_samThis is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it... -
This specification for the HP ProBook 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 450 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...09-06-2024, 06:20 AM
- Loading...
