Panasonic TCP50C2 10 Blinks
  • svc
    • Oct 2013
    • 16
    I have a Panasonic TC-P50C2 and it is blinking 10 times upon power-up. So, I found a Panasonic "Technical Guide" (for 2010 13th gen plasmas) which includes a troubleshooting flow chart for blinking LEDs. Results are as follows:
    1. Disconnect SS and SC boards - # of blinks changes to 7
    2. Reconnect SS board - # of blinks changes back to 10
    The guide says "Replace the SS board" which I would like to interpret as "Fix the existing SS board" but I don't know what's wrong with it.
    The silk screen indicates this board is a TNPA5072. All replacement boards I can find have an alpha suffix and that adds a lot of uncertainty to the matter when I consider the alternative of replacing the board.
    I would greatly appreciate any advice on troubleshooting this board or identifying an acceptable replacement. Thanks in advance!
    Steven
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TCP50C2 10 Blinks
    I have a similar SS on a 42", common failure, the SMD IGBTs short, looks like RJP30E4? Q001,Q002,Q021,Q022. You could test gnd to Vsus on SS connector SS11 and I'm expecting it's shorted.
    I have not found an exact datasheet but the E3 is 40Amp, looking at the way they've run the numbers RJP30E4 I suspect is 360V 45amp Silicon N Channel IGBT made by RENESAS. package is D-pak
    I fixed mine with different transistors not quite the same although mine TV has display issues still so unsure if what i did is part of the problem.
    Given the relative low cost of a used/refurbished/pulled fron new Tv damaged in transit board it's probably best to get the board.
    Yours is TNPA5072 no suffix or TXNSS1LNUU but any 50" TNPA5072 SS board including the Sanyo models should work. I believe there was a change in production on the type of connector for the panel ribbons but they still fit and connectes correctly.
    REV AE looks the same just it has a lever action connector where the Panasonic you pull the collar out , insert and push the collar in and it clamps. The other one I found has different capacitors that would be because the panel model must have changed as the boards are tuned to the panels.
    Panasonic original
    Rev AE fitted to SANYO with panasonic panel
    RJP30E4 example
    Up to you to decide which to get.
    • svc
      • Oct 2013
      • 16
      Thanks tw2005! I found a 5 pack of the IGBTs on eBay for $10 so I'll try that first. I attempted to spec the transistor but there are minute differences between the E2 and E3 which leaves me with a lot of uncertainty about the E4 so I'd rather not push my luck. If these don't work, I'll pick up a new board.
      That said...I got the pins off the board without issue but I'm struggling with the body of the units...any tips for removal?
      Thanks again!!
      • tw2005
        • Oct 2011
        • 6458
        Thanks again!!
        Flux, tin the tab up with solder so you get good heat transfer and heat the transistor tab until it start bubbling and slides. I think I used a broad tip on a cheapo 40W iron
        • svc
          • Oct 2013
          • 16
          That worked almost too well to be true. Thanks 10^6
          • tw2005
            • Oct 2011
            • 6458
            No worries, please decode 10^6 for me ?
            Did you check out the rest of the board for shorted components like the FET driver or those tiny 5pin npn/pnp transistors. I had no issues apart from those FETs.
            EDIT: Ok Thanks a million, HA HA. 10^0 is fine.
            • svc
              • Oct 2013
              • 16
              Sorry, forgot to subscribe to this thread. Yes, that was thanks a million!
              The FET driver is fine. In testing the transistor packages, they're either bad or I have the pinout wrong:
              (Where both emitters and both bases are connected)
              PNP:
              B - 1/4
              C - 2
              E - 3
              NPN:
              B - 1/4
              C - 5
              E - 3
              Do I have these right? If so...how do I go about testing them? I would think a simple open circuit across each C - E would do it...but they're tied together in a different way than I'm used to. If I was taught this, I slept through it...
              • tw2005
                • Oct 2011
                • 6458
                PNP:
                B - 1/4
                C - 2
                E - 3
                NPN:
                B - 1/4
                C - 5
                E - 3
                Pin outs, tested in cct on a SC board, should be similar
                • svc
                  • Oct 2013
                  • 16
                  Yeah, had the pin out wrong...hahaha....
                  All 3 of those units are bad. Again I get about 300kohms when I should have 3Mohms. I'll order them later today...found in stock at Mouser. 3.50 for 6 of them but 20 in shipping...blahhhh
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                    After all of...
                    07-13-2024, 08:14 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
                  • Biruslapio
                    Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                    by Biruslapio
                    Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                    It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                    It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                    02-16-2021, 09:44 PM
