Possible Purchase - Vizio
  • Dangermoose007
    • Sep 2013
    • 44
    • US
    Seller was asking $150 a week ago, now asking for $100. As you can see the TV a really faded white picture, do you know what the possible causes could be?
    Right now I don't know the model #, or plasma/LCD, all I know is that it's 42" still waiting for a response from the seller. I'll update the thread once I have more info
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Possible Purchase - Vizio
    if it is a lcd, i would look at the as15 chip on the t-con.
    if it is a plasma, i would look at the x-main.
    hope this helps a little.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • cadiman
      • Mar 2010
      • 397
      I get these for 20 bucks or leave them alone!
      I would not pay 100.00 for any tv today.
      • Dangermoose007
        • Sep 2013
        • 44
        • US
        Okay, found out the model vo420e. There's another guy in my area who also buys and repairs tvs off CL who has shown some interest. I offered $25, we'll see.
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • howardc64
          Vizio SmartCast TV software bug that looks like hardware
          by howardc64
          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
          11-16-2024, 05:17 PM
