I have an olevia 242-t11 that I am attempting to repair. The tv turns on normally, and the backlight comes on, but there is no picture, either from the inputs or from the menu button. The first thing I did was check the caps on the powerboard, and they all appear fine. The caps on the mainboard and both inverters appear good also. After doing some more research, I discovered it was most likely a blown fuse on the t-con board. I tested it, and it is passing a charge. I don't even know what else I should check. Any suggestions?
Olevia 242-t11 No picture
Re: Olevia 242-t11 No picture
I have a similar problem. Was a fix found for this issue? Thank you!Comment
For those looking to test capacitors, get a B&K 881 in-circuit capacitor checker. I love mine! It saves a lot of time since you do not have to unsolder them from the board.Comment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started βfading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly βnew' Tcon board this time, and... -
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
- Loading...
