Dynex DX-32L150A11 Standby Blink
    replied
    Re: Dynex DX-32L150A11 Standby Blink
    And many more amps short circuit. Not unless you want to incinerate what is causing the short.
  • ohmmy
    replied
    Wait can't I just use an iPhone wall charger? They're rated at 5v 1a output
    replied
    Yes you can buy resistors like that, they are very large with a big heatsink.
  • ohmmy
    replied
    Is there any load I could use instead of a resistor to limit current?
    And how long do you keep it running to determine the fault/part that gets hot
  • ohmmy
    replied
    Originally posted by tom66
    You might be able to use a ~4.5V battery (or 5V from computer PSU) and a 4.7~5.1 ohm resistor (rated minimum 10W) to do the freeze spray test.
    Ha nice. We posted at same time. I don't think I have any resisters rated at 10w though. Do they even make that value resistor with that much wattage?
  • ohmmy
    replied
    You freeze spray parts of a board whilst passing a small current (around 1 amp) through it. The parts that melt the freeze spray likely have the short.
    To try this could I use an old pc psu using the 5v rail and a resistor to limit the current to 1amp?
    So using ohms law, the resistor to use: R=5/1 = 5ohms?
    replied
  • ohmmy
    replied
    This almost seems impossible to trace without a schematic. It looks like the 5v line goes through some smt capacitors and an aluminum electrolytic cap before a 1.8v regulator. The voltage at the input of that regulator fluctuates the same as when measured at the 5v pin
    replied
    134 ohms is low, but not what I would consider dead shorted, because of that, I would be looking for a short "hiding" behind a device, for example, a diode in series with a short after a diode.
  • ohmmy
    replied
    From the 5v terminal to ground I get a reading of 134ohms. I found the same exact measurement on a smt cap on both ends. It's a shade of grey. No clue what the rating would be. Could this mean it's shorted?
  • ohmmy
    replied
    What resistance did you measure at the 5V terminal directly on the main board, compared to those at the caps/Vreg?
    So I'm looking for the same reading I get from the 5v terminal to ground when checking others components to ground?
    replied
    Low resistance: generally less than 10 ohms is a concern.
  • ohmmy
    replied
    I'll have to retest and get back to you. Just left my house. What should I be looking for exactly?
    replied
  • ohmmy
    replied
    It would be on that 5V line.
    I traced it to a couple smt capacitors and a couple voltage regulators. Do I need to check them off board for shorts? They don't test low ohms as of now, neither do the caps
    replied
  • ohmmy
    replied
    Would the short be on that 5v line or anywhere? I could try tracing it on the mainboard
    replied
    Shorts are traced by testing resistance along the board, looking for low readings, it can be very difficult on a meter with only one decimal point which is why I suggest the current method, but that requires a constant-current constant-voltage lab power supply.
  • ohmmy
    replied
    PC fan ~100mA is fine for a standby type load, yes it indicates a short on the main board.
    What you need to do is either try tracing for shorts using an ohmmeter, or try my favourite method which involves freeze spray. You freeze spray parts of a board whilst passing a small current (around 1 amp) through it. The parts that melt the freeze spray likely have the short.
    How would I trace for shorts using an ohmmeter?
    When I have mainboard plugged in, every component seems cold to the touch, in the past I'd at least notice some warmth on a faulty component.
    Wouldn't know how to exactly only pass 1amp to the entire board while freeze spraying
    replied
  • Cookybaby
    Samsung UN60ES6500FXZA Power Supply Issue
    by Cookybaby
    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
    Make: Samsung
    Model: UN60ES6500FXZA
    Power Supply P/N: BN44-00525A
    Symptoms: The TV was...
    08-20-2023, 12:26 PM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • EazyBone
    Un50cu7000 2 blink oddity *partially solved
    by EazyBone
    I write this to maybe help another with this TV.
    So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
    The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
    03-18-2024, 10:24 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
