Dynex DX-32L150A11 Standby Blink
    replied
    Re: Dynex DX-32L150A11 Standby Blink
    What resistance, board powered down & unplugged from power board, do you get across 5V now?
  • ohmmy
    replied
    Removed that regulator and now I have steady 5.20v at that rail and steady standby light. Power button doesn't do anything.
    Anyway to test the regulator with ohmmeter? I have a bad feeling there's a short at its output somewhere and regulator is good.
  • ohmmy
    replied
    Originally posted by tom66
    In a way but not really, also it would need to be in series with one of the power outputs to do such a job. (A computer fan has transistors in it to switch various motor windings, it switches rapidly between near zero and near infinite resistance.)
    Wouldn't wired in series drop the voltage at the output?
    replied
  • ohmmy
    replied
    Doesn't work without resistors to divide current between equal or dissimilar voltage sources.
    Isn't a fan a type of resistor (load)? Just trying to learn as a go. Thanks for helping along with this. Been helpful
    replied
  • ohmmy
    replied
    I don't know what you mean by doing that... You'll probably find one power supply or another will take the whole load so it should be the same as with PSU? A 1.8V regulator could be the cause, you can remove it for a test (the set will not work right but it should have 5V steady.)
    Doesn't current divide in a parallel circuit? That's why I connected the fan in to cut amps going to the main board. I could be wrong but it was quick thinking to limit current since I don't have proper resistor. Will remove regulator and see what happens.
    replied
  • ohmmy
    replied
    Well before seeing your reply I went ahead and connected the fan I used to load the psu for testing (12v .22A) in parallel with iPhone charger to supply the main board. Figured in parallel it'll cut down the current going to the board.
    Used some freeze spray and instantly noticed the 1.8 regulator warm up. Now my question is, could that be the fault or whatever it's powering? I'd imagine it'd be connected to the processor with a voltage that low at its output.
    replied
    Yes, it does. The resistor is in series at all times.
  • ohmmy
    replied
    Does the resistor's wattage still have to be high with a power supply only rated at 1A?
    Also, do I connect the resistor in parallel or series?
    replied
    The same for any charger >=1A. Approx 5.1 ohms.
  • ohmmy
    replied
    You need a resistor and a power supply capable of supplying at least 1 amp.
    What value resistor if I use the iphone charger thats rated at 5v 1amp out?
    replied
  • ohmmy
    replied
    oh ok, would I still need the same type of resistor mentioned before or?
    replied
    Yes, you do still need one. Such a charger is capable of well in excess of its rated output when driving a short circuit.
  • ohmmy
    replied
    I assume you are thinking about directly connecting omitting the resistor? That is what I am saying is bad, on its own a power supply with the resistor should be OK.
    The resistor was for using a cpu psu but now I'm talking about a small phone charger that outputs 5v 0.7a, I'd still need a resistor for that?
    replied
  • ohmmy
    replied
    I have another charger with output of 5v 0.7a. Would that be safer?
  • ohmmy
    replied
    And many more amps short circuit. Not unless you want to incinerate what is causing the short.
    Thought you said to use minimum 1amp supply? I have some other phone chargers rated at 5v out with lower amps ratings than the iPhone one. What's ideal amps output to use?
  • Cookybaby
    Samsung UN60ES6500FXZA Power Supply Issue
    by Cookybaby
    Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
    I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
    Make: Samsung
    Model: UN60ES6500FXZA
    Power Supply P/N: BN44-00525A
    Symptoms: The TV was...
    08-20-2023, 12:26 PM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • EazyBone
    Un50cu7000 2 blink oddity *partially solved
    by EazyBone
    I write this to maybe help another with this TV.
    So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
    The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
    03-18-2024, 10:24 PM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
