Dynex DX-32L150A11 Standby Blink
  • ohmmy
    • 182
    Re: Dynex DX-32L150A11 Standby Blink
    The connector on my mainboard with the 5v is at connector x601 but I don't see it anywhere in the manual? Just x501
      Other possibles
      C529, C538, C528, C531, C533, C520.
      You can lift: L505, L624, L504, L502 to isolate these rails and capacitors, may be easier.
      If short disappears on one, then you know where to look.
      Predominately a short to ground that low is almost always a capacitor or FET, and I can only see capacitors on that line.
      Could be hard to read 5/6 on board?? Do check common components to see if general layout is close.
      • ohmmy
        • 182
        Here's a close up pic of the area I removed the regulator and where x601 connector is on left
        • ohmmy
          • 182
          I only have R603 on the adjustable leg of that regulator, it's supposed to be 510ohms but it measures 313ohms, that's in circuit. Does it need to be out for accurate reading? Would the low ohms create the problem?
            The schematic may be slightly different then, but if the general blocks are there, should be fine, is that reading with or without reg in place? Sure you did not accidentally pull off it while removing reg?
            • ohmmy
              • 182
              Reading is without regulator, and I'm sure there's not even any pads for another resistor there. Also I found one small smd capacitor near processor CS38 that measures 0 ohms as well as two others in the area but none of which are on the 3.3v circuit shown in the schematic that also measure 0 ohms.
              There are lots of caps, inductors shown in schematic that I can't find on the board
                Looks to be different variant then, is that possibly wrong main board for this set?
                • ohmmy
                  • 182
                  Hmm so I continuity tested both ends of that CS38 cap with the output pad of the regulator I removed and meter beeped both times, will try to remove it and see what happens after I place regulator back in.
                    Just remember a cap will show short if other things are in parallel, but from that schematic if it's at least close there isn't -much- on that rail. Maybe 10~15 caps tops.
                    • ohmmy
                      • 182
                      Removed cap, back to same problem with regulator in circuit.
                      I can't find the corresponding caps next to it as shown in the schematic.
                      • ohmmy
                        • 182
                        Found the short! It was the tiniest smd cap CS27 figured closest to CS28 on the schematic since I could not find that one. I did some continuity measurements and there were three caps all linked together including that one, it was second I removed and boom got my standby light.
                        With it removed though pressing power button doesn't do anything.
                        How can I substitute another? These things are so small with no markings. Could I just use any off a junk board?
                          Measure one near it, will likely be same value. Typically 100nF. Yes you can use one off a board if it is same value. Do you get 3.3V or 1.8V or whatever at that regulator now?
                          • ohmmy
                            • 182
                            Oddly the output voltage of that regulator is now only reading 0.6v. What's up with that? Did it go bad after finding the short?
                            • ohmmy
                              • 182
                              Also I'm confused. I looked up that regulator and it says it needs two resistors to work but there's only one connected to it on the board. I've looked and looked, only one. Even found same mainboard on ebay and the picture up only has one resistor.
                                Such a regulator when using only one resistor has an output of 1.2V.
                                • ohmmy
                                  • 182
                                  Since the regulator is not outputting I wonder if I even found the short.
                                  I have some fixed value 3.3v regulators, could I use one to replace it and just put a jumper where the resistor is?
                                    I think it's probably not a 3.3V regulator, doing that could cause damage, you need to replace it with the exact type (1117 ADJ.)
                                    • ohmmy
                                      • 182
                                      Know where I get a couple?
                                        Digikey, eBay... a few bucks and a few days wait (the hardest part about any repair project!)
                                        • ohmmy
                                          • 182
                                          Ha yeah. I feel like the short is still there. Wonder if it's even worth the hassle
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
