Dynex DX-32L150A11 Standby Blink
    Re: Dynex DX-32L150A11 Standby Blink
    134 ohms is low, but not what I would consider dead shorted, because of that, I would be looking for a short "hiding" behind a device, for example, a diode in series with a short after a diode.
    • ohmmy
      • 182
      This almost seems impossible to trace without a schematic. It looks like the 5v line goes through some smt capacitors and an aluminum electrolytic cap before a 1.8v regulator. The voltage at the input of that regulator fluctuates the same as when measured at the 5v pin
        You might be able to use a ~4.5V battery (or 5V from computer PSU) and a 4.7~5.1 ohm resistor (rated minimum 10W) to do the freeze spray test.
        • ohmmy
          • 182
          Originally posted by tom66
          You freeze spray parts of a board whilst passing a small current (around 1 amp) through it. The parts that melt the freeze spray likely have the short.
          To try this could I use an old pc psu using the 5v rail and a resistor to limit the current to 1amp?
          So using ohms law, the resistor to use: R=5/1 = 5ohms?
          • ohmmy
            • 182
            Ha nice. We posted at same time. I don't think I have any resisters rated at 10w though. Do they even make that value resistor with that much wattage?
            • ohmmy
              • 182
              Is there any load I could use instead of a resistor to limit current?
              And how long do you keep it running to determine the fault/part that gets hot
                Yes you can buy resistors like that, they are very large with a big heatsink.
                • ohmmy
                  • 182
                  Wait can't I just use an iPhone wall charger? They're rated at 5v 1a output
                    And many more amps short circuit. Not unless you want to incinerate what is causing the short.
                    • ohmmy
                      • 182
                      Thought you said to use minimum 1amp supply? I have some other phone chargers rated at 5v out with lower amps ratings than the iPhone one. What's ideal amps output to use?
                      • ohmmy
                        • 182
                        I have another charger with output of 5v 0.7a. Would that be safer?
                          I assume you are thinking about directly connecting omitting the resistor? That is what I am saying is bad, on its own a power supply with the resistor should be OK.
                          • ohmmy
                            • 182
                            The resistor was for using a cpu psu but now I'm talking about a small phone charger that outputs 5v 0.7a, I'd still need a resistor for that?
                              Yes, you do still need one. Such a charger is capable of well in excess of its rated output when driving a short circuit.
                              • ohmmy
                                • 182
                                oh ok, would I still need the same type of resistor mentioned before or?
                                  You need a resistor and a power supply capable of supplying at least 1 amp.
                                  • ohmmy
                                    • 182
                                    What value resistor if I use the iphone charger thats rated at 5v 1amp out?
                                      The same for any charger >=1A. Approx 5.1 ohms.
                                      • ohmmy
                                        • 182
                                        Does the resistor's wattage still have to be high with a power supply only rated at 1A?
                                        Also, do I connect the resistor in parallel or series?
                                          Yes, it does. The resistor is in series at all times.
                                          • Cookybaby
                                            Samsung UN60ES6500FXZA Power Supply Issue
                                            by Cookybaby
                                            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                            Make: Samsung
                                            Model: UN60ES6500FXZA
                                            Power Supply P/N: BN44-00525A
                                            Symptoms: The TV was...
                                            08-20-2023, 12:26 PM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
