haier l37a8a-a1
  • willyam1
    • Feb 2012
    • 112
    • israel
    haier l37a8a-a1
    hi to all.
    problem is pic is ok for a few sec then freeze and then fic fade away slowly and then vertical lines in all the screen.
    i change the main board just in case no luck.
    some meserment in TCON vgh=16 vgl=-6v vcc=3.3v 1.5v in out reg .
    by scop can see signals in the input of the tcon cabel.
    i dismantale the screen and check the ribbon cabel all ok.
    is it screen or the TCON BOARD =6870C-0158A.
    THANKS WILLYAM1
  • willyam1
    • Feb 2012
    • 112
    • israel
    Re: haier l37a8a-a1FREEZE PIC
    [QUOTE=willyam1;384694]hi to all.
    vgh in scope showing a pulsses its semms to me that its not correct its sould be steady dc like vcc vgl vdd need to know wich ic supply that valltage is itTPS6561 OR RT8901 OR COULD BE A SMD CAPI OR DIODE.
    WILLYAM1
      Re: haier l37a8a-a1
      Is VGH pulsing when pic OK?
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: haier l37a8a-a1
        yes its also pulsing when the pic is ok.the tv is conected to my laptop and when i change the page the last pic is shwoing but not the newone and slowly fade away.
        the vgh always with pulses.
        willyam
          Re: haier l37a8a-a1
          Can we see a picture of the t-con? Need to see if it has RAM memory.
          • willyam1
            • Feb 2012
            • 112
            • israel
            Re: haier l37a8a-a1
            i will send pic tomorrow i think its vgot a ram memory
            • willyam1
              • Feb 2012
              • 112
              • israel
              Re: haier l37a8a-a1
              any data on the chip RT8901
              • willyam1
                • Feb 2012
                • 112
                • israel
                Re: haier l37a8a-a1
                solve.
                i change the ic rt8901 now i got 24v pic ok.
                willyam
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • netgearnetgear
                  TCL 43S423 TCON OR PANEL FAULTY???
                  by netgearnetgear
                  Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                  08-20-2025, 06:04 PM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
