Sony KDL-52W3000
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Sony KDL-52W3000
    I have a Sony KDL-52W3000 that doesn't turn on. I tried to check the fuse and the bridge rectifier but they don't seem to be bad. There are no bulged caps neither.
    I'm stuck and I don't know what the next step is. Can someone help me out please?
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Re: Sony KDL-52W3000
    anyone please?
    • matthmal
      • Nov 2012
      • 306
      • Malta
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Could you post us a close-up picture of the plugs on the power supply that go to the main board so we can see the labels? Also, a picture of the entire back showing all boards.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          It would be best for reference if it was in the TV with the wires hooked back up for this. Also, have you checked the 5V pins with the power connected to see if you even have standby voltage present?
            Download the service manual first:
            • aaronwt6
              • Apr 2013
              • 855
              • US
              If you decide there is no voltage coming from the power supply, I'd personally have a hard time justifying spending much time on it. That thing is available for around $15 shipped.
              • freakaftr8
                • Oct 2012
                • 3743
                Yes check for 5v standby before anything else
                • matthmal
                  • Nov 2012
                  • 306
                  • Malta
                  Please find attached the photos as requested. They may not be the best photos but I am trying to improve them.
                  I didn't find the 5V connector but I found a 6V connector which gave me the reading of 6.3V while the TV is on standby. The socket that I tested is marked with red on one of the pictures.
                  I also tested a 12V connector that only gave me 1.2V.
                  Kindly advice if I messed up.
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    I downloaded the manual and skimmed through it. I will read in more detail later on today.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      I'm about to leave work so will have to look at this again later but I can't read any of the labels at the connectors on the power supply. Need clear pictures of the board labels there. Maybe someone else can lend a hand in the mean time.
                      • matthmal
                        • Nov 2012
                        • 306
                        • Malta
                        Please find attached photos of the labels on the power board. (named label1 and label2)
                        I also attached photos showing the connectors to other boards, one of the pictures named tested has the connector which I check for the 6V voltage.
                        I also noted that someone else tried to replace a cap on this board and it seems like he damaged the board. I marked the damage done to the board on the photo named traces. I am not sure as to where the traces from the cap are going. Can someone help me figure out where the traces are going so that I can check for continuity please?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Ok 12v is achieved when the set has powered on mainboard. 6v must be standby
                            That capacitor is so badly soldered it might as well not even be there. Cold jointed everywhere. Ugh. It's also a crappy generic cap, probably radioshack in origin, so would suggest replacing it anyway with e.g. Panasonic FC/FM/FR.
                            • matthmal
                              • Nov 2012
                              • 306
                              • Malta
                              ok so when I get home, I will clean the motherboard and will do some more tests. Will post more photos too.
                              • matthmal
                                • Nov 2012
                                • 306
                                • Malta
                                I temporarily replaced the capacitor with a normal one for the time being so that at least we can get it up and running.
                                I cleaned the board and resoldered the cap. One of the legs become cold soldered since the board is a bit damaged but now I figured out the traces and checked for continuity. I will easily bridge the cap by means of a small wire.
                                Tomorrow morning I will post voltage readings of the board.
                                • matthmal
                                  • Nov 2012
                                  • 306
                                  • Malta
                                  hey guys, i found the 5v standby pin and when testing it sometimes it gives me out of range and sometimes I get 20v going down to 0.01V. Sometimes I even see 5.4V.
                                  I cant test the voltages on the other pins as the set doesn't even power on.
                                  I tested the fuse and it seems fine. I also tested the bridge rectifier and it gave normal readings. Should I still post them here?
                                  Any ideas please?
                                  • truep
                                    • Aug 2010
                                    • 373
                                    Is meter set for DC volts? If set to AC, it can give strange readings like that.
                                    • matthmal
                                      • Nov 2012
                                      • 306
                                      • Malta
                                      Not sure, I will confirm in a few hours
                                      • matthmal
                                        • Nov 2012
                                        • 306
                                        • Malta
                                        Guys,
                                        I have re-done the tests on 200V DC:
                                        CN6150:
                                        12v > 2.3
                                        12v > 2.3
                                        12v > 2.3
                                        12v > 2.3
                                        NC -> 000
                                        6V -> 2.2
                                        6V -> 2.2
                                        CN6151:
                                        12v > 2.3
                                        12v > 2.3
                                        6V -> 0.6
                                        CN6152:
                                        12v > 2.3
                                        12v > 2.5
                                        Audio VCC -> 2.5
                                        Audio VCC -> 1.8
                                        CN6153:
                                        NC > 000
                                        NC > 000
                                        Balanced EAA > 0.1
                                        12v > 2.2
                                        INV EAA -> 000
                                        Back Light -> 1.2
                                        Dimmer -> 000
                                        CN6154:
                                        Balancer EAA > 000
                                        INV EAA > 000
                                        Back Light > 0.8
                                        Dimmer -> 000
                                        AC RLY -> 2.4
                                        PFC DET -> 0.8
                                        PS EAA -> 2.2
                                        STDBY 5V -> 2.3
                                        NC > 000
                                        Any suggestions?
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO SVF1541M1E Notebook Fit E Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF1541M1E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF1541M1E boardview and SVF1541M1E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
