Samsung Pn50c680 black line
  • RedMonte
    • Oct 2013
    Hi, I was hoping someone here could help me answer some questions. I have a samsung pn50c680 plasma tv and a small black line just popped up the other day on the screen. The TV is about 3-4 years old and gets used pretty frequently.
    This black line seems to look as if the pixels are not lit. The black line appears behind menus and is located about 3 inches down from the top of the screen. It runs horizontally across the entire screen and appears to be only a single pixel wide (very thin line).
    I have read over some of the guides posted here by tom66 and several other posts around the web and what I have concluded is that this could possibly be due to having a faulty connection between the ribbons that connect the display to the y-sustain board.
    I have not yet pulled the back of the tv off to try and reseat the ribbons but that will be the first thing I try. If it is not the connections themselves, is it most likely faulty circuitry on the y-sustain board?
    Or...are these the early symptoms of a failing plasma panel ?
    Also, the tv had some very light and almost unnoticeable reddish bleeding in the upper right corner area...this occurred sporadically through the last year of ownership. It was only noticeable on black or very dark screens and even then it was feint.
    Thanks for any help and input! Much appreciated!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung Pn50c680 black line
    well unfortunately it sounds like a bad screen this model Samsung around this year have been playing with black horizontal line showing up on the screen this is an apparent problem and it means that your screen most likely is not repairable. Unfortunately more will eventually show up.
    of course you could always go the route of taking the TV apart and try to reseat the y buffer ribbon cables.
    • RedMonte
      • Oct 2013
      That is unfortunate...well I guess I will tear the back of the tv off and atleast give the ribbon connections a try. Thanks for the help.
        09-07-2024, 05:50 AM
      • J8rda7
        Samsung UE40F5570SS -Black line and partially ghosted/blurred
        by J8rda7
        when I received this TV, there was a faulty T-con (missing all voltages, only 12V OK), black screen, sound OK, backlight OK.. So I replaced the T-con and now it looks like this.. Thank you Very much for any hints, what I must to check or measure etc.. Have a nice day and sorry for my english 🙂...
        05-09-2024, 11:37 PM
      • madyoyo
        Samsung eu58tu6928k - Short on CK3 line -
        by madyoyo
        Hello.
        I have a Samsung eu58tu6928k with the dreaded bootloop fault.
        No external tcon, one 96 pins ribbon between mainboard and the left side of the panel, and a ribbon to the right side.
        I narrowed the problem down to the CK03 line. When i isolate only this line on the ribbon joining the 2 halves of the panel, the tv boots, but the picture is quite bad. I also tested all MLCC caps on the panel, no short so far. Is there anything i can try before ruling the panel, and the whole tv as scrap?...
        11-05-2025, 04:55 AM
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
