60ps11 Vertical Lines
+ More Options
Posts
  • crdz66
    • Nov 2012
    • 242
    Hello Fellas.
    I have a Lg 60ps11 with 2 vertical lines crossing the screen. (top-bottom)
    Does these lines caused for a buffer boards (called x-board right on lg) ?
    or Sustain boards.
    Re: 60ps11 Vertical Lines
    Unfortunately they probably mean the plasma display panel is bad, which is not economically repaired. Can we get a picture of the fault?
    • crdz66
      • Nov 2012
      • 242
      Yes of course.
        That could just be a loose connector for that part of the panel or a bad control board.
        • crdz66
          • Nov 2012
          • 242
          Thanks tom66
          I going to open this tv and check.
          • freakaftr8
            • Oct 2012
            • 3743
            I second the control board. Refit.ribbon cables to start.
            • crdz66
              • Nov 2012
              • 242
              Hi.
              Something I did it was disconnect the control board from x-board left (because does lines show to the left looking at from back) and from x-board center and those lines still are on the screen.
              • freakaftr8
                • Oct 2012
                • 3743
                Disconnect the wide white ribbons from control board to bottom of the screen and reconnect
                • freakaftr8
                  • Oct 2012
                  • 3743
                  and if that doesn't work try taking a wooden dowel or something like the back of a screwdriver and while you're watching the screen push on the main IC on the control board and see if the lines disappear
                  • crdz66
                    • Nov 2012
                    • 242
                    I did it that but still lines are there.
                    both ways (disconnect and push the ic)
                    • crdz66
                      • Nov 2012
                      • 242
                      training manual for this tv (page 97)
                      show
                      if there is a bar defect on the screen it could be a control board problem.
                      maybe?????
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Yes. If I were you id order t he control board. If there were only one line I would be more thinking screen defect but two leads me to believe its the control board.
                        • crdz66
                          • Nov 2012
                          • 242
                          Thanks for you advice buddy.
                          I going to try to get and let it know.
                          • crdz66
                            • Nov 2012
                            • 242
                            Hello Fellas.
                            I already change the control board and still have two vertical lines.
                            Bad panel?
                            Thanks.
                              It is possible for the C boards/X boards to do this too but unlikely.
                              • crdz66
                                • Nov 2012
                                • 242
                                But what is the chance panel is bad???
                                  That is more than possible.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Sorry for the advice on changing the control board. Its a crapshoot sometimes.
                                    • Ashroyer05
                                      • Sep 2013
                                      • 162
                                      • U.S
                                      • Stanley1843
                                        by Stanley1843
                                        06-29-2024, 11:54 AM
                                      • Falki
                                        Colorful LCD Vertical Lines on Samsung ue55es8090
                                        by Falki
                                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                                        A similar issue has been posted as well but also with no actual response ...
                                        08-12-2025, 04:19 AM
                                      • visionbluedemon
                                        Help. Sony kd-65x85dj vertical lines
                                        by visionbluedemon
                                        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                        tried blocking LC lines too, but same results
                                        is it lcd panel issue or tcon board issue?...
                                        07-25-2025, 04:56 AM
                                      • gpo23
                                        Sony KDL-40V3000 - Vertical lines
                                        by gpo23
                                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                        With the new t-con the color are good but there are vertical lines on all the screen :
                                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                        Is there a way to fix the vertical lines on the new t-con ?
                                        Thank you for your help
                                        gpo23...
                                        10-04-2023, 09:11 AM
                                      • Firentiosi
                                        1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                        by Firentiosi
                                        Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                        The issues are as follows: the...
                                        11-27-2024, 12:33 AM
