Does anyone know where to get a pinout for this chip? There are two on the board. One acts as though three of its pins are common and the other chip acts as though only 2 of it's pins are common. I'm trying to find a short and i'm hoping this is all it is.
L-367 65626
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by pickledeggHello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...10-02-2024, 04:54 PM -
by Big PookaHello All,
I'm a hobbyist at best, I've built a few radio kits (I'm a Ham), but other than that I'm a newbie at electronics.
A friend gave me a Samsung UN60EH6003 that works about 50% of the time. Specifically, it demonstrates the common Samsung dreaded dead screen and blinking standby light when you try to turn it on. To be more specific, 50% of the time when you press the power button it starts normally, 50% of the time when you press it the screen does not come on, there is no startup tune sounded, and the red standby light blinks slowly.
When it... -
by J_TI have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
Sorry, I am not experienced hence a basic question.
- Loading...
