Problems with Insignia 42" Plasma
    Re: Problems with Insignia 42" Plasma
    There isn't such a thing as a titanium cap AFAIK, it's probably a small snubber capacitor of the order of a few hundred picofarads at 1kV.
    • MacCormac
      • Sep 2013
      • 18
      Hi Tom66
      Yes you were right
      I searched around on the net and found a pdf service manual for NS-42PDP
      it had a schematic of my power board and I found the cap to be a 330pf 1Kv
      I,ve yet to get one and replace it.
      • MacCormac
        • Sep 2013
        • 18
        Hi Guy's
        I finally replaced the small 330pf cap on the supply board to no effect.
        I've also tried swapping out the Zsus board, also to no improvement.
        If I play with the up/dwn pots on the Ysus board during startup of the TV,
        I can speed up the clearing of the screen, but I have't to readjust again for
        sparkles and rainbow effects alittle while later as the TV comes up to normal running temperature
        Still original problem but watchable after about ten minutes
        still stumpped
        • MacCormac
          • Sep 2013
          • 18
          Hi Guys
          Spent a few more hours read postings for a 42' LG Plasma and came across a post by grbgemen (screen slowly fills up).
          In that posting RayRod81 talked about the caps around the UP/DWN setup pots causing this problem on the Ysus board, not the Zsus board.
          Because he was talking about a 52" model, the cap# numbers didn't match my board.
          I looked at the baord and I had approx 6 caps at the 10uf 350v size in the area of these pots.
          I replaced them all with 10uf 450v caps and the tv comes on right away now.
          Out of the 6 caps two were bad using an ohm meter to charge and check them.
          Now I have to try and setup the voltages and setup pots to get rid of noise and Sparkles.
          Thanks to all for your help so far
          • KYBOSH
            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
            by KYBOSH
            Saved this beast from the landfill this weekend.
            Manfactured July 2013 in Mexico.
            I love working on plasma TVs.
            Its been a while but I was lucky enough to find 2 this week.
            The TV powers on and stays on but no picture. Havent checked for sound yet.
            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
            Will start troubleshooting tonight.
            10-17-2024, 01:17 PM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • jose6326
            Insignia Ns-l22x-10a no picture only sound
            by jose6326
            When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
            When i was removing the back cover i heard a rattle.
            Removed the metal plate and the heat sink was off (see pic)
            would this cause a no picture/image issue?
            What is used to put back the heat sink
            07-30-2024, 11:03 PM
