Problems with Insignia 42" Plasma
    Re: Problems with Insignia 42" Plasma
    There isn't such a thing as a titanium cap AFAIK, it's probably a small snubber capacitor of the order of a few hundred picofarads at 1kV.
    • MacCormac
      • Sep 2013
      • 18
      Hi Tom66
      Yes you were right
      I searched around on the net and found a pdf service manual for NS-42PDP
      it had a schematic of my power board and I found the cap to be a 330pf 1Kv
      I,ve yet to get one and replace it.
      • MacCormac
        • Sep 2013
        • 18
        Hi Guy's
        I finally replaced the small 330pf cap on the supply board to no effect.
        I've also tried swapping out the Zsus board, also to no improvement.
        If I play with the up/dwn pots on the Ysus board during startup of the TV,
        I can speed up the clearing of the screen, but I have't to readjust again for
        sparkles and rainbow effects alittle while later as the TV comes up to normal running temperature
        Still original problem but watchable after about ten minutes
        still stumpped
        • MacCormac
          • Sep 2013
          • 18
          Hi Guys
          Spent a few more hours read postings for a 42' LG Plasma and came across a post by grbgemen (screen slowly fills up).
          In that posting RayRod81 talked about the caps around the UP/DWN setup pots causing this problem on the Ysus board, not the Zsus board.
          Because he was talking about a 52" model, the cap# numbers didn't match my board.
          I looked at the baord and I had approx 6 caps at the 10uf 350v size in the area of these pots.
          I replaced them all with 10uf 450v caps and the tv comes on right away now.
          Out of the 6 caps two were bad using an ohm meter to charge and check them.
          Now I have to try and setup the voltages and setup pots to get rid of noise and Sparkles.
          Thanks to all for your help so far
