Sasung M87, problematic back light inverter.
  • Dang
    • Aug 2013
    • 440
    Hi, I hope some one can clarify the part I need here. I have a Samsung LE40M87BDX which has been suffering from a non starting back light, it powers on fine, has sound but just no back light(a torch shows up menus), upon looking and with a little testing using a DMM and a hair dryer, it seems part number KIA78M12T is at fault, it's a three terminal positive voltage regulator. There's a 12 volt feed that should run to the inverter, but this is at 8.13v only raising to 8.43v once warmed up, if I heat it up with the hair dryer for about 10 seconds it shoots up to over 10v allowing the Tv to power up properly, at about 9.5v the back light struggles to get going, once on it holds at a constant 9.48v. The problem I'm having is finding an equivalent, I can't find the exact part and I'm not familiar with these so not sure what is suitable.
    I have found a data sheet for the exact part but it's a little alien to me, page No5: http://pdf1.alldatasheet.com/datashe...KIA78M12T.html If someone could help me source an equivalent replacement from the likes of eBay, I'd be very grateful, thanks, Andy.
    Re: Sasung M87, problematic back light inverter.
    What input voltage do you get feeding this 12V regulator? May be Vin is too low for it to regulate.
      Depending on the package it would be equivalent to a 7812 in TO-220 or DPAK, but check Budm's suggestion first. A 78xx requires at least 1.8V more on the input than the output to regulate correctly.
      • Dang
        • Aug 2013
        • 440
        Thank you to both of you, I shall have a look tomorrow morning and let you know, Andy.
        • Dang
          • Aug 2013
          • 440
          OK, measured V-in and it's only at 13.43v, I believe it should be at something close to 19v so quite a discrepancy, any ideas on what else could be causing this? thanks again, Andy.
            Bad capacitors on the input... what is BN44 number of power board?
            • Dang
              • Aug 2013
              • 440
              Hi, it's a BN44-00165A. From the voltage regulator I did follow the track back from V-in and yes, it leads to the usual capacitors that fail, as to what one or few I don't know, none are raised, bulged or leaking???
                Schematic
                  The 78M12T looks to be a low dropout variant of 7812 so 13.3V is fine (and is indicated on schematic as MULTI13V.) You could probably use an LM2940-12
                  https://cdn.badcaps-static.com/pdfs/...daece7257c.pdf
                    Disconnect CNI806 to see if the output will go back up to 12V. The output also feed 22 Ohm resistor for the IC VCC.
                    • Dang
                      • Aug 2013
                      • 440
                      Thanks again to both of you. OK, so upon looking at the schematic I'd agree, V-in looks to be correct although the datasheet does show 19v as V-in, the resistor R1814 measures at 22.3 Ohms so perfectly fine, there is a cap just beside the voltage regulator which I've changed as a precaution, no change to the output though. I've found this: http://www.ebay.co.uk/itm/1108307299...84.m1438.l2649, is this possibly what I'm after?
                      CN1806 was disconnected and tested, still exactly the same.
                        If you disconnect all the loads from the output pin and install 100 Ohm 2W (or 47 Ohms 5W) as the load, if the out put is still not 12V then we know for sure that the IC is bad, we are trying to find out if the output is low due to heavy load or due to bad IC.
                        • Dang
                          • Aug 2013
                          • 440
                          OK, just to clarify, I disconnected the stated connector, the two main inverter power cables and then tested pin 1, still exactly the same result, I then reconnected them back up and used the test pad just below the connector on the inverter for V-out, still exactly the same result. I'm not too sure on your method but I would guess the above would show the inverter to be OK, so seen as V-in seems correct it would point to the voltage regulator being bad, but that's just my guess.
                            This is what I would use
                            http://www.ebay.co.uk/itm/LM2940CT-1...item2a0fb48f45
                            The 7812 is not low drop out so may not work properly.
                            Also, turn the TV on, run it for about 15 mins with fault. Then turn it off and feel regulator, is it burning hot? Or just cool/warm to touch?
                            • Dang
                              • Aug 2013
                              • 440
                              Thanks for the pointer, I'll get back to you a little later on the 15 minute power up, thanks again, Andy.
                                Just if you use that part, I would recommend you solder a 22uF or greater capacitor (16V rated or more) between output and ground because it might be unstable (oscillate) otherwise. Any capacitor will do - does not have to be low ESR type.
                                • Dang
                                  • Aug 2013
                                  • 440
                                  Thanks again, had the Tv on for the 15 minutes, just stayed cool if not cold. I shall try my local Tv repair centre for the part tomorrow, they're usually quite good, if a no go I shall try your recommendation, I'll post up my findings in due course. Once again thank you to the both of you for your time, it has been a great help, Andy.
                                  • Dang
                                    • Aug 2013
                                    • 440
                                    Hi again, I have one last question before ordering the part, the part you recommended requires a decoupling capacitor to smooth out it's output, why would the original not require one?
                                    I have found this :http://www.maplin.co.uk/1a-low-dropo...egulator-46321 at Maplin(it's just down the road from me), it says it's a TS78M05 if you hover over the picture, I'm sure the 05 should be a 12 so hopefully in stock, do you think this would be suitable and still need the decoupling capacitor?
                                      Just because the original part is hard to get hold of, this one is an alternative part but requires a small capacitor to make it work properly. The Maplins one is not a low dropout regulator and is 5V rated, you need one rated for 12V. Low dropout is important because it might not produce the right supply voltage once the unit has been running for long.
                                      • Dang
                                        • Aug 2013
                                        • 440
                                        Hi, yes, I realize the above and bought this one: TS78M12CZ, , upon checking it's specification sheet it looks very close to what I had and I've now installed it, the Tv now works with an 11.8v feed to the inverter, a small drop of 1.5v andit's been on for over an hour without issue, just what the doctor ordered. Thanks again, it was certainly informative and of course, as always, very helpful, Andy.
                                        The next I have is a Sharp 37HV4E, usual stuck in stand by start up issue, thanks again.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • jdawg99
                                          LG 47LA620V Same LED Failing Back Light Issues
                                          by jdawg99
                                          Hi All,
                                          I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                                          04-23-2023, 01:04 PM
