Panasonic TC-50PS14 10 blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-50PS14 10 blinks
    Ok so with the one inverter that's out, what does vcc-gnd on the ic measure?
    • tw2005
      • Oct 2011
      • 6458
      SO you reported 2 shorts on that reg is that still true or are we down to 1 or 0? We've established tab and 2 are the same so on the input you have ? Output you're reporting 30 ohms at this stage.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        The reg itself appears to be OK at this point, tab and center are the same so only fault appears to be beyond the reg with 30 ohms to ground. Input as I recall was right around 5 k I can verify tonight when I get back home. I don't remember what VCC to ground was on ic773 but will also post when I get home.
        Liberating magic smoke one part at a time
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          Ok tested ic773 off board and get 900 ohms between Vcc and ground, and 336k between 2 and 4. Lifted ic464 and ic465 both showed 60 ohms between Vcc and Ground (5 and 3). now have 439k between vout (1) and ground (2) and 257 ohms between ground and vin (3) With all those parts off the board Im getting 384 ohms across d523 now so we are making progress.
          • tw2005
            • Oct 2011
            • 6458
            You should use diode mode to test the diodes in cct. I'm out of those inverter chips so can't check a new one. If 2 are bad, just replace all 3. Not too sure about the 200 odd ohms on the 16V that feeds teh FET driver too, could be bad. maybe someone can check their board and compare?
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              I tested the diode itself and its good (in cct in diode mode as well as one side lifted), with one side of the diode lifted I still get 384 ohm across the pads, I havent had time to try and test out the fet driver, may just end up replacing it if I can ever get to the end of this parts list.
              Btw the fet 16604 (B1CHPM000001) is looking like it may be difficult to source is there a compatible replacement?
              • tw2005
                • Oct 2011
                • 6458
                Yeah, I know. P-channel fet. I don't think I could work out a sub for it. UTSOURCE on EBAY lists them at $2 ea or you'd have to order direct from Sears or someone like that which makes for an expensive repair.
                I was looking at a TNPA4410 from the PZ80 and it has one of those on it. I wonder how many useful parts would carry over. There's one for $24 free post in oregon ohio.
                You'd have to grab the respective manuals and search the OEM numbers to see what hits you get.
                • Caleb
                  Smokin IC's
                  • Feb 2013
                  • 645
                  I have one of those TPNA4410's, I will have to take a look and see if that part is good, maybe I can salvage some more parts off that board as well, thats where I pulled those 88 diodes from. It gave 7 blinks but I saved it for parts.
                  • tw2005
                    • Oct 2011
                    • 6458
                    You may be able to, are the transistors shorted out on the 4410. Ther's probably a few parts on that or even test point we could use for comparison like the FET driver which are the same.
                    looks like there is only 1 tiny inverter ic on that. I would put some time looking at what is usable, could cut the cost down quite a bit.
                    Looks like you'll luck out on the IGBTs but I'm seeing other useful stuff if we can prove they're ok and you can get them off cleanly and desolder the leads. It's messy but I've done this in a pinch for some really hard stuff for me to get.
                    Those 5pin npn/pnp transistors are on that (5) this is good if they are ok, hard to get
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      When I tested it the vscn circuit wasn't working properly, as it was for someone else and the replacement was only 40$ I just swapped it out and upped the bill 40$. I saved it for parts if I got another one in, it looks like that was a good move. I tested that p channel fet and get much better readings on board than on mine. I was too bushed after work to do much on it last night. I saw it has the same fet controller ics as well, at least I can get a point of reference on what my readings should be. I will print a part sheet from that board and see what else I can use (and see which igbts you are referring too). Those inverter ics are only a buck each from utsource
                      • tw2005
                        • Oct 2011
                        • 6458
                        they're much cheaper than that and texas instruments make an equivalent. i got mine at UT but a buck each seems the lowest unit price they quote.
                        It takes 3 weeks to get here I have no idea china - us.
                        You can copy and paste from the PDF the part details into excel.
                        I was saying I don't see any iGBTs the same but have not gone right into it. But what they have there may?? e of similar spec?
                        Q661 RJP6065, RJK6075 on the older model would be close except wrong package. Both would be 600v .
                        Anyway if you can work out what that board can't donor and get some transistors on the way or list what transistors are on those heatsinks. The 3 pin fast recovery diode blown that older board has a couple of those there so you won't need them.
                        • Caleb
                          Smokin IC's
                          • Feb 2013
                          • 645
                          I looked through both boards and it looks like 4401 has all the parts I need except for the 3 fets and 1 igbt. I guess I will go ahead and order those and hope I dont need anything else.
                          • tw2005
                            • Oct 2011
                            • 6458
                            I could only see 1 schmitt inverter ic though, how many did you find?
                            TI equivalent SN74AHC1G14DBVR for TC7SH14F.
                            The suffix is the size,I think there's a few.
                            ?SN74AHC1G14DBVR
                            • Caleb
                              Smokin IC's
                              • Feb 2013
                              • 645
                              according to the schematic there are 5 of the same part number on the sc
                              ic16773
                              ic16603
                              ic16464
                              ic16465
                              ic16564
                              • tw2005
                                • Oct 2011
                                • 6458
                                ic16773
                                ic16603
                                ic16464
                                ic16465
                                ic16564
                                On a TNPA4782, yes. 2 are bad, I'd get extras just in case.
                                On a TNPA4410 in a 50PZ80, no.
                                I can only find the 1, IC16564 C0JBAB000715
                                ic16773, does not exist
                                ic16603, does not exist
                                ic16464, does not exist
                                ic16465, does not exist
                                ic16564, C0JBAB000715
                                • Caleb
                                  Smokin IC's
                                  • Feb 2013
                                  • 645
                                  Well that would explain why when I looked at the board I couldnt find any of those numbers. I was using the search function built into the pdf reader you told me about and clicking back and forth from schematic to schematic. I guess the search function was bringing up pages from both schematics. I found them on digikey for a mere 3 cents each....the only bad part you have to buy 3000 of them. I will get a few of those as well. Thanks for your insight on this project.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    That's why I gave you a TI equivalent, the Toshiba part is probably harder to find.
                                    But they are a little dearer than I thought so a buck each at UT is probably ok.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      #98
                                      Well guys. I got the parts in today and installed. Plugged the set in, hit the power button, and blew them all again in less than a second. At least I got some noise and a nice fireball. Back to the drawing board I guess.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Yes, and also now have probably additional items damaged. It's rare just for the IGBTs to fail.
                                        It's a tough gig to find them all, a little luck is needed too sometimes.
                                        • Caleb
                                          Smokin IC's
                                          • Feb 2013
                                          • 645
                                          Thats a bummer for sure. Havent got mine yet but I kinda have a feeling I will have a similar experience- at least you didnt pay 75$ for the repair kit.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • CrewmanRedShirt
                                            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                            by CrewmanRedShirt
                                            Hello all,
                                            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                            07-13-2024, 11:02 AM
