White screen on my sony bravia KDL-V3000 lcd
  • Normanxrx
    • Oct 2013
    • 9
    • Netherlands
    Hi There,
    I got white screen on my sony bravia KDL-40V3000 lcd when I turn it on. First you can see the menu but very, very bleached. In some seconds it turns all white and two red led start blinking continuously. In other instance it stays white screen with barely visible menu/functions but after changing the sources or program in the menu it turned completely white with continues two red led blinking. If I remove t-con the screen turns dark(not black). Could it be t-con or those symptoms are from damage main-board?
  • Normanxrx
    • Oct 2013
    • 9
    • Netherlands
    Re: White screen on my sony bravia KDL-V3000 lcd
    Is there anybody that can help me on white screen issue?
    • freakaftr8
      • Oct 2012
      • 3743
      well you could try disconnecting the ribbon cables from the t-con board and go to the panel and power the TV up see if your if it down with the red lights blinking still
      • freakaftr8
        • Oct 2012
        • 3743
        it could be at tcon board it could be a panel there's no tellingif the panel has it that short it will probably take out the t-con board and then send it error code. But considering the fact you get a picture you could try disconnecting the panel and then connect one ribbon cable at a time and see if the problem persists
          Sounds like Gamma voltage ref problem.
          See reply here since you post in two places, please stick to one thread, easier for us to track.
          https://www.badcaps.net/forum/showth...469#post380469
          • Normanxrx
            • Oct 2013
            • 9
            • Netherlands
            Thank you for your suggestions. I did try to connect only one side of t-com ribbon cable and with one side of ribbon cable connected the screen stayed white and with other went dark(not black!). I have ordered new t-con and we'll see...
            • Normanxrx
              • Oct 2013
              • 9
              • Netherlands
              Just got t-con & after changing it the picture went perfect!
              But unfortunately if I change in the menu from digital to analog the screen goes again white and two read led start blinking. After turning TV off/on manually(no respond from remote) and in menu change back from analog in to digital pic is good.
              Also after connecting my laptop to it via hdmi picture is great until I shut down the comp - screen of TV goes white with two blinking red led. Can anybody give some creative idea how to solve this problem?
              • freakaftr8
                • Oct 2012
                • 3743
                Try updating the firmware.
                • Normanxrx
                  • Oct 2013
                  • 9
                  • Netherlands
                  I can't find it! Any link suggestions? Or any other suggestions...
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Does this tv have a network port? Im not sure but if it does you may be able to firmware update through the menu
                    • Normanxrx
                      • Oct 2013
                      • 9
                      • Netherlands
                      No, it doesn't have.
                        Does it have USB?
                        • Normanxrx
                          • Oct 2013
                          • 9
                          • Netherlands
                          No, also not.
                          • Pragmatiko
                            • Jul 2013
                            • 468
                            • IT
                            please put picture of your t-con... high resolution i am refer to original t-con
                            • Normanxrx
                              • Oct 2013
                              • 9
                              • Netherlands
                              After replacing the T-con I have found the second hand motherboard for GBP 12,- and it work again perfectly!!! Thank you all for your help & ideas!
                              • Ihandyrepair
                                sony 55X850D black screen no front white or red led light.
                                by Ihandyrepair
                                Hi guys
                                strange one
                                I have a dead Sony 55X850D
                                when plug in, black screen, no front white or red LED, no back light no screen
                                Voltages I get
                                3.3v LD/power and main board
                                reg 12V
                                reg 19V
                                3.3v on power on pin
                                no Tcon on
                                no tcon 12v
                                no BL_on
                                I do get BL_ERR 2.0v
                                I tried to bypass it by ground it but still get same symptom
                                I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                or is possible the chip next to...
                                08-07-2024, 04:58 AM
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • harp
                                White screen repairs
                                by harp
                                To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                05-13-2024, 03:43 AM
                              • Yehuda170
                                ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                by Yehuda170
                                original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                with original broken screen i can see in device manager touch screen in human interfaces
                                but with the new screen it's not showing in device manager
                                is it lenovo blocking it? is it driver missing?
                                I²C is a headache
                                07-14-2023, 01:29 AM
                              • JUCaESAl
                                Sony bravia KD-65AF9
                                by JUCaESAl
                                Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                10-20-2025, 04:03 AM
