Lg 50pv450
  • TennesseePaul
    • Oct 2013
    • 29
    Lg 50pv450
    Hi, I am brand new here but came upon this site while searching for help with a 50PV450 I have. I will be very grateful for any help that can be given.
    The issue I have is as follows:
    I have an LG 50PV450. I recently acquired three boards for this TV. I picked up a new power supply board, and new YSUS board and a new main board (there were damaged HDMI ports in this TV, hence the new main board).
    I've installed all the boards, as I'm fairly skilled with a screw driver, but now all I see are "sparkles" for a moment and then the TV goes black.
    I happened upon this site through this thread.
    It seemed to discuss a similar issue, though on a different TV set. I was wondering how I would go about resolving the sparkle issue for this set. I have questions such as, how do I find the proper set points for this panel? I noticed the Vs and Vr on the Power Supply, how do I adjust these properly and what makes them different than the, I think it was 4, settings on the YSUS board?
    Thank you in advanced. I look forward to any response.
    TennesseePaul
    Re: Lg 50pv450
    There is a problem with the Y-sus, control, Y-buffer or Z-sus, in that order, if you see sparklies when powered on but no picture then appears. Voltage/setting adjustment will not help for now. In some cases initial sparkling may be normal if it goes away once set is displaying an image. Do the sparklies go away? It may be normal power up procedure.
    Can you supply a picture of the control board (sometimes called logic)? There is a test jumper on most of them which can be activated to see if the new main board is bad, which will cause dark slightly glowing screen with no visible image. In a very dark room do you see any glow from the plasma screen?
    • TennesseePaul
      • Oct 2013
      • 29
      Re: Lg 50pv450
      Hi Tom,
      Thank you for the reply. I will work to get the answers for you, but must state before hand that this may take a while. I have a 1 year old in house, so all work must be done in the evenings to avoid frying the little guy.
      Q: "Do the sparklies go away?"
      A: Yes. When I power on the TV, the screen shows pretty black with scattered sparkles that then disappear after a few moments.
      Q: "Can you supply a picture of the control board (sometimes called logic)?"
      A: I will work to get that image posted this evening. --EDIT: I am not certain off the top of my head where this would be located. I know the YSUS (upper left), Power Supply (center), ZSUS (upper right) and Main (lower right).
      Q: "In a very dark room do you see any glow from the plasma screen?"
      A: I am not entirely certain. When I powered it up, there was maybe a glow and sparkles scattered about, but it appeared to go all dark after a few moments. I can see if I can make the room darker to see if it is actually still "glowing" after the initial event. I tend to think not though.
      Thanks again for your reply. I really appreciate the help.
      --EDIT: I've been working off this manual.
      Tennessee Paul
      • TennesseePaul
        • Oct 2013
        • 29
        Re: Lg 50pv450
        Hi Tom,
        Attached are the images. I tried to capture the full "boot-up" screen but wasn't fast enough with my camera.
        When it first starts up, the entire screen is "sparkled".
        Then it is only half the screen. Then it goes dark.
        I can tell there is some "light" going on in there. Perhaps a back light. But, even in a dark room, the "glow" you mentioned I wasn't able to see. If there was a plasma glow, then it did not appear. But I could tell there was some sort of light going on there. It looked like a black image vs a turned off set.
        Included are also the pictures of the boards and the entire back of the panel.
        Tennessee Paul
          Re: Lg 50pv450
          To me, it looks like a bad Y-buffer or Y-sus, possibly both.
          You can try this test to see what you get. Perform the changes with power off, then plug it in. You should see a sequence of test patterns if it's working, but I suspect you will see nothing more than you currently see. This board is the control board.
          • TennesseePaul
            • Oct 2013
            • 29
            Re: Lg 50pv450
            Hi Tom,
            Thank you for the response.
            The changes you are talking about are replacing the 2 boards you mentioned?
            TennesseePaul
              Re: Lg 50pv450
              No, I'm talking about powering it off when following the instructions in the image attached.
              • TennesseePaul
                • Oct 2013
                • 29
                Re: Lg 50pv450
                Hi Tom,
                I see now. Thank you for the clarification. I will give that a try tonight.
                Tennessee Paul
                • TennesseePaul
                  • Oct 2013
                  • 29
                  Re: Lg 50pv450
                  Hi Tom,
                  Wanted to post an update so as not to disappear. I have been swarmed by other duties lately. I plan on getting to this tomorrow. At that time will have more information on the results.
                  Thank you,
                  Tennessee Paul
                  • TennesseePaul
                    • Oct 2013
                    • 29
                    Re: Lg 50pv450
                    Hi Tom,
                    I did as instructed. The screen didn't do all that much. It showed some pixels as before but even less briefly. The color was largely red. Then it went dark.
                    Tennessee Paul
                      Re: Lg 50pv450
                      Can you check your old Y-sustain to see if the picture is any different?
                      • TennesseePaul
                        • Oct 2013
                        • 29
                        Re: Lg 50pv450
                        The old board hissed high pitch and clicked. With it in the TV will not power on. It cycles attempts, but never succeeds.
                        • TennesseePaul
                          • Oct 2013
                          • 29
                          Re: Lg 50pv450
                          Out of curiosity, what did the jump do?
                            Re: Lg 50pv450
                            The jumper enables the internal test pattern generator. (The LVDS cable must also be removed to enable it.)
                            Can you check the -Vy and Vsc voltages on the Y-sustain? They will be labelled. To test, put your meter across the indicated points set to the highest DC range.
                            • TennesseePaul
                              • Oct 2013
                              • 29
                              Re: Lg 50pv450
                              Interesting. Could I have jumped poorly? I did not solder. I just put a wire end in each.
                                Re: Lg 50pv450
                                If the result is different (you noticed a difference right?), it cannot have been the connection. That is how I would jumper it, just a wire or bent paperclip.
                                • TennesseePaul
                                  • Oct 2013
                                  • 29
                                  Re: Lg 50pv450
                                  Yes. It was different. In a few I will post the results of the meter.
                                  • TennesseePaul
                                    • Oct 2013
                                    • 29
                                    Re: Lg 50pv450
                                    Vsc starts off high. Around 178 but falls off to 0.
                                    Vy starts off high, over 200, but falls off quickly and ends at 0.
                                      Re: Lg 50pv450
                                      OK on the back of the metal backing of the plasma panel (inside the unit) you have a sticker marked e.g. LG Electronics PDP50xxxxxxxxx with voltages like VS: 206V, VA: 58V marked on it. Can you take a picture of this sticker?
                                      • TennesseePaul
                                        • Oct 2013
                                        • 29
                                        Re: Lg 50pv450
                                        Hi Tom,
                                        Attached is the picture.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
