Lg 50pv450
    Re: Lg 50pv450
    I don't trust those readings. If it were truly over 500V then the Y-sustain would be severely damaged - suggest you check your probes and location of testing.
    • TennesseePaul
      • Oct 2013
      • 29
      Re: Lg 50pv450
      I will. I have a better tool at my office I will procure for an evening.
      Am I measuring the correct points?
      • weimars
        • Dec 2013
        • 13
        Re: Lg 50pv450
        I was wondering if anything has been resolved from this diagnosis? It looks like the thread just ended. I'm researching an only sound, no video problem from my LG 60PV450 and was reading from this thread interested on how it turned out. Thanks for the update if possible. Maybe I'll just start a new thread...
        • jb_gt_84
          Repair hobbyist
          • Dec 2013
          • 9
          Re: Lg 50pv450
          Hi, I'm a newbie who also has a LG 50PV450 w/ this same problem.
          I'm also curious about a resolution.
          • weimars
            • Dec 2013
            • 13
            Re: Lg 50pv450
            Check out this thread...
            https://www.badcaps.net/forum/showthread.php?t=33717
            It shows what I did to fix my tv. It turns out to be a bad main board. Good luck.
            • TennesseePaul
              • Oct 2013
              • 29
              Re: Lg 50pv450
              Sorry for the delayed response. Finally got a good meter home. World of difference that makes!
              So, with the ysus unplugged from the panel and Zsus, I dialed in the voltages spot on. Waiting for the caps to dissipate before reconnecting. Just excited to use a good meter.
              • TennesseePaul
                • Oct 2013
                • 29
                Re: Lg 50pv450
                Still the same result. No white fuzz even when not connected to a video source. The screen is not completely lit, then half lit, then off.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
