Samsung LE32A456C2DXXU line down middle of screen
  • trigger
    • Aug 2013
    • 16
    • uk
    I have a line down the middle of the screen. Do i need to replace the screen ?
    Re: Samsung LE32A456C2DXXU line down middle of screen
    Depends on the line, can you submit a photo? Most likely though you will have to replace it but that probably won't be worth it.
    • trigger
      • Aug 2013
      • 16
      • uk
      Its about 1 pixel wide. I guess it might be cheaper to buy a new TV. So annoying !!!!
        These TVs are notorious for bad panel problems. Stuck lines, dark bars and full field random noise all due to panel failure.
        • trigger
          • Aug 2013
          • 16
          • uk
          Thanks for that, I think I'll keep it for spares.
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • KYBOSH
            Trying to Save - Samsung UN55JS6500 - A line down the screen + Falling LED diffusers
            by KYBOSH
            Picked this one up today.
            In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
            From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
            Wanted to get a 2nd opinion from you guys before I gave up the ghost.
            Great looking TV otherwise.
            Is there any tricks I can do to try to save this one?
            If so, i'll gladly order a set of backlights and save this one from the landfill..
            Thanks in advance
            10-04-2024, 11:00 PM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
