phillips 52pfl3704d
  • joe904
    • Aug 2013
    • 27
    • usa
    phillips 52pfl3704d
    I have a Phillips 52pfl3204d that when you turn on Phillips banner comes on the screen for 2seconds then tv shuts off. checked for blown caps all appear good . I seem to think its the tcon board .. problem started when hdmi port 1 went out connected to port 3 worked fine for short time then sound went out . then picture . I get the Phillips banner at the bottom of screen then it shuts off . any help or suggestions
  • johnboy1313
    • Nov 2012
    • 1959
    Re: phillips 52pfl3704d
    If you unplug the t-con, does the tv stay on?
    • joe904
      • Aug 2013
      • 27
      • usa
      no it doesn't come on at all nothing
      • joe904
        • Aug 2013
        • 27
        • usa
        I have a main board for a 52pfl3603d/27 is this compatible with a 52pfl3704d/f7
        • huzo
          HP Omen shuts down when loading OS
          by huzo
          The model is 15ec-1061nm
          Board number is DAG3EDMB8D0​
          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
          10-29-2024, 12:05 AM
        • chaos-theory
          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
          by chaos-theory
          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
          03-14-2025, 05:37 PM
        • baglaivlad
          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
          by baglaivlad
          Hello everybody!
          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
          11-20-2024, 08:14 AM
        • samuelphirik
          Dell inspiron 15 7567 sudden shuts down
          by samuelphirik
          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
          Now I've noticed that laptop...
          07-02-2023, 05:45 AM
        • nickgronk
          Hisense 55H6570F boots, loads then shuts down -
          by nickgronk
          I have a Hisense 55H6570F that gets the the boot loading screen for android and then shuts down. Oddly I hear a crackle on the mainboard as shown in the picture - nothing looks blown. The tv will boot every time, but when it reaches the loading statge of the anroid logo you can hear crackling on the board and it shuts down. What am I looking for (other than buying a new set) ? Inside the square is where I hear the crackling
          08-05-2024, 11:02 AM
