Fujicom 37 lcd
  • willyam1
    • Feb 2012
    • 112
    • israel
    Fujicom 37 lcd
    Hi.
    pic is very bright can sea colors.
    usely problem in tcon board.
    I change same tcon board used one (not new) but no sure if its working ok and its the same problem.
    TCON T370HW02 37T04-COG.
    Most of the time im replacing the as15-hf ic and the problem is solved.
    befor I change the HS15-HF here some result.
    vgh=26.30v.
    vgl=-6.6v.
    12v 3.3 1.2v in reg.
    HAVDD=7.8V.
    AVDD=15.9V AND THE VOLLTAGE IN THE CAPI SMD C502 C503 C504.......C509 IS IN GOOD ORDER NOTHING IN THE BOARD IS HOT.
    notice that the pic is little bit flicks (not the backlight) but without input signsl ther is no flicks also the 2.6v in the output adj reg is little rippel and the 5v and12v little rippling in the main board .
    heat with hotgun the capi in the power supply and in the main board no luck the same any solution?the screen is T370HOW03 THANKS WILLYAM
    Re: Fujicom 37 lcd
    Pic of T-Con? Check GAMMA voltages?
    • willyam1
      • Feb 2012
      • 112
      • israel
      Re: Fujicom 37 lcd
      hi tome66 all the reading point of the gamma are in good order
      I change the AS15HF SAME PROBLEM.
      WHAT NEXT?
        Re: Fujicom 37 lcd
        How did the gamma voltages test? What voltages did you get?
        • willyam1
          • Feb 2012
          • 112
          • israel
          Re: Fujicom 37 lcd
          Vg1=15.3 vg2=15 vg4=12.53 vg6=10.92 vg8=10.05 vg10 =8.87 vg11=8.63
          vg12=7.65 vg15-5.6 vg17=4.68 vg19=3.15 vg21=0.538 vg22=0.3.
          I didnt find vg3 vg5 vg7 vg9 vg14 vg16 vg18.
          Willyam
            Re: Fujicom 37 lcd
            OK, that looks OK. Check user menu, what are settings for brightness & contrast set at?
            • willyam1
              • Feb 2012
              • 112
              • israel
              Re: Fujicom 37 lcd
              50%in scale from 0 to 100.
              NOTICE THAR RESISTANCE IN THE 1.2V PIONT IS LOW 52OHMS AND ITS THE VOLLTAGE FOR THE MAIN IC IN MAIN BOARD
              IT SEEME THAT THE PANNEL OR MAIN IC IN MAIN BOARD NOT OK MAIN BOARD TM30G V1.O 2009.11.18.
              WILLYAM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • netgearnetgear
                TCL 43S423 TCON OR PANEL FAULTY???
                by netgearnetgear
                Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                08-20-2025, 06:04 PM
