LG 42LB5DF No Pic No Sound
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 42LB5DF No Pic No Sound
    You mean like local dimming ? This is not an LED, I wasn't aware they could implement that type of function with CCFL's ?
    Besides, though the backlight is on I still have no pic, I should still suspect the T-Con, no ?
    • mmartell
      • Oct 2013
      • 3189
      Ordered another T-Con, will update when it arrives.
        It is not local dimming, it is for the whole screen, not like the backlit LED.
        • mmartell
          • Oct 2013
          • 3189
          Ok received and replaced the T-Con board.
          Result - Same symptoms.
          If I unplug ribbon from tcon to master inverter backlights fire up no problem. If I slide that cable back in then as soon as it makes contact inside the socket the backlights go out.
          Any ideas ?
          • mmartell
            • Oct 2013
            • 3189
            I've attatched two pics of either end of the flat cable connecting the T-Con to the Master Inverter.
            If the cable is unplugged the backlight works and the voltages are as follows on the inverter
            Dim_In ~ 2v
            Dim_Out ~ 2v
            Sen_CB 5v
            Whenever the cable is plugged in, the backlight goes out and the voltage on the Sen(sor?) Pin goes to 0v.
            I checked that pin on the tcon board and it appears to be grounded which can't be right ?
            Did I get a bum board or should I be looking elsewhere ?
            • mmartell
              • Oct 2013
              • 3189
              And the pics...
              • mmartell
                • Oct 2013
                • 3189
                T-Con Pin 5 of Con1 (Pic one above - Labelled Sen_CB on matching Inverter pin) shorts to ground on both my original and the used one as shipped to me.
                However the inverter shows 5v on that pin so when I plug that cable into the tcon that 5v goes straight to ground and shuts off the backlight. I can't see where that pin goes on the board to even trace it but I'm guessing it shouldn't be grounded.
                Help Please !!
                • mmartell
                  • Oct 2013
                  • 3189
                  I realize not everybody wants to read through three pages to get involved so I will summarize as if this were the first post
                  TV was found to have no backlight - all voltages from PS seemed to check out as good.
                  Unplugging the ribbon cable from the Master Inverter to the T-Con allowed the backlight to operate as normal but still no pic or osd.
                  Replacing T-Con with used yielded same result.
                  5v was found at Inverter (see above post) which grounds out on the T-Con for both the original and replacement.
                  Did I get a bad board or do I have a problem somewhere else ?
                  • mmartell
                    • Oct 2013
                    • 3189
                    I sent off several emails to ebay members who are selling this tcon asking if they'd test the pin in question for a short to ground.
                    I have received several replies, inconclusive as I can't even be sure they are testing the proper pin etc.
                    They overwhelmingly report that pin shorted.
                    This only confuses me further. The implication is that there shouldn't be 5v on the matching inverter pin but my gut is telling me it SHOULD be there - even without a schematic.
                    I've d/l the SM from Elektrotanya but it doesn't appear to have a standard schematic so is useless to me.
                    HELP !
                    • dhallet
                      • 6
                      Any resolution with this unit?
                      • mmartell
                        • Oct 2013
                        • 3189
                        No.
                        I tried two replacement T-Con's with same results.
                        Am going to order a mainboard at this point as I can't imagine what else it could be.
                        • dhallet
                          • 6
                          I am working on one with the same symptom. I just got off the phone with LG tech assist and he said to change the T-Con if it's not that then try the main board and if that don't do it try the inverter. Geesh, I said, so LG tech assist is saying just throw boards at it till you find which one fixes it. That's great. The tech assist guy just laughed and said "Yup". I then asked why are the back lights coming on if I disconnect the ribbon cable coming from the inverter to the T-con and he said "I have no idea why it is doing that and I cannot find out why it is doing that". Keep us informed on the result with the main board. I am thinking, like you, it has to be the main board. I don't have a scope at the moment to see if there is in fact video being outputted by the main. Good luck Keep us informed on what the main board does.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Strange isn't it ? Did you measure 5v at the SEN_CB pin too ? And of the three T-Cons I have laid hands on the matching pin is grounded so how does that make sense ? Which is why I could see that circuit on the inverter could have malfunctioned...
                            But since there is no video I think a mainboard should be first.
                            • mmartell
                              • Oct 2013
                              • 3189
                              And btw I came across a Russian site that claims if you put 1.5v on the TST_PGM pin of the T-Con it will output a test pattern onscreen. Have not tried it myself - the mainboard is currently out of the unit as I was going to check for high esr caps. I think it's possible that other than the BL_ON voltage the mainboard may be outputting incorrect signals to the inverter.
                              • dhallet
                                • 6
                                Any word on the fix for this set?
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I put it to the side as I received another unit that took my attention for a bit.
                                  Since then I have acquired an oscilloscope (which I haven't used before) and will be using it soon to test for the presence of video signal or lack thereof coming from the mainboard.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Hey dhallet it looks like in my case the chip PI3HDMI341 (hdmi controller ?) is shorted out. I also have another short in one of the supply lines to the BCM chip so I'd have to assume at minimum the mainboard is faulty and a replacement is necessary.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Update: Installed replacement main board. Set fired right up, osd visible as was tuner noise and cycled through inputs.
                                      Reassembled the unit and remounted to neighbour's wall only to find all inputs dead. Fu@k! That's a rookie mistake I won't make again.
                                      However, I did NOT plug back the ribbon cable from the inverter to the t-con for fear of blowing something again on the main board. (I measured the voltage on the suspect pin and it was still there so I decided to be safe since I had backlight without it)
                                      Does anyone know if there is any feedback in that circuit that would prevent the inputs from working or did I get a bum replacement? ?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Hmmm... there were at least three size variations of this set. Are those mainboards interchangeable ???
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          Main board replacement working fine. TV back to life. Thanks to all.
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
