LG 42LB5DF No Pic No Sound
  • mmartell
    • Oct 2013
    • 3189
    When connected to mains power light flashes for some time then stays lit. Some time after that I hear a relay click and I am then able to power it on with the button on the panel. Voltages at the power supply connectors as follows:
    ACD / 5v
    PWR ON / 3.3v
    5Vs / 5v
    I-C / 3.3v
    ERR / 0v
    BRI / 5v
    DIM / 1.7v
    6V / 6v
    3.4vON / 1.9v
    All other voltages are present as follows (stated/actual) :
    19V / 18.5v
    6V / 6v
    3.4V / 3.4v
    12V / 11.8v
    24V / 24.2v
    At this point the power button is unresponsive.
    What to check next ?
  • mmartell
    • Oct 2013
    • 3189
    Re: LG 42LB5DF No Pic No Sound
    The pin labelled "ERR" is labelled in the SM as "5V Det/Error Out" and also "5V_MNT" and despite the name is designated an INPUT.
    Is this the pin which goes high to tell the PS to produce the 5V rail for the main board because not only does it read 0V I don't see where the 5V output pin is to measure it ?
      Right now the main is getting correct voltage to run otherwise it will not put out PS_ON to turn on the 12v/24v power supply.
      Can we see the pictures of the boards?
      • mmartell
        • Oct 2013
        • 3189
        Not at home atm will post them tomorrow...
        Where is this VA/VS supply voltage I see mentioned ? I don't see it marked on the PS board.
          "Where is this VA/VS supply voltage I see mentioned ?" This is LCD TV not Plasma TV.
          • mmartell
            • Oct 2013
            • 3189
            Got it.
            • mmartell
              • Oct 2013
              • 3189
              Here's a pic of the topside power supply board. I don't see any bulging capacitors or anything else amiss.
                OK, pictures of the inverter board? The whole back side of the TV so we can see what we are dealing with. Any labels on the connectors of the Inverter board will help also.
                • mmartell
                  • Oct 2013
                  • 3189
                  Ok cool, I had the main board out but had since put it back in with the shield on hence no pic of that.
                  Umm... the inverter board is (are) the boards to the far left and right ?
                    I cannot tell until I can see the whole back side of the TV, it may have one or may be two inverter boards.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Ok will get pics up soon.
                      • mmartell
                        • Oct 2013
                        • 3189
                        The four caps each on Master and on Slave pass a visual inspection. They read in the range of 6000uf (in parallel ?) But their esr is extremely low.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Forgot to attach pics...
                            OK, CMO inverter boards, check ALL the fuse, including this tiny F5 one that looks like resistor in this example.
                            • mmartell
                              • Oct 2013
                              • 3189
                              I tested the four fuses as shown between the capacitors on both boards and they tested for continuity. Should I test for voltage on both sides of the fuse instead ?
                                Yes. By the way, you said 4 fuses, two on each board? The board also has the small black fuses as shown on post14
                                http://www.shopjimmy.com/philips-996...verter-kit.htm
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I'm going to remove one of these boards then to have a closer look under my magnifier to locate that fuse then reinstall and test for voltages at the fuses.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Located the smaller fuse on the Master inverter - did not find a similar one on the Slave.
                                    Tested the Master Inverter and found 24.2v before AND after all three fuses. I notice there is a TCON connector to the Master inverter, any way to test that ?
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Tested the Slave Inverter and found 24.2v before AND after the two fuses.
                                      What kind of voltage is running to the panel through the edge connectors on the Inverters ? If the panel itself was broken would that shut down the power supply or not ?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        I have to apologize, Bud ! I just realized I've been stating the facts wrong.
                                        Although I have no pic, more precisely I have no backlight !
                                        Also where I stated I have no sound I can't say for sure as I haven't connected a source because I can't tell which input I'm on anyhow (as I have no OSD and no remote control)
                                        Now...
                                        I have 24v to other side of fuses on both inverter boards...
                                        I have 3.3v on I-C pin which is the Backlight_ON control...
                                        yet I still have no backlight.
                                        q. Can the TCon board keep the backlight from turning on ? If so can the set be turned on with that board disconnected from the inverter ?
                                        q. Is it possible to measure the output of the inverter to see if there is voltage (HIGH VOLTAGE!) ? Obviously if there is voltage at the output I could conclude the panel (backlight) has failed.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
