Re: sharp aquos LC-80LE632U led tv lamp error
Nothing on the pinout is defined as lamp_error. Just error. I tried removing the pin from the loom and also tried shorting the pin to ground using a 150 ohm resistor. same fault. I have researched the net and found someone who had the same fault on a.70 inch version and he replaced the inverter/power supply to restore the backliight issue cause he had no backlights at all with any key combination he tried. Then had the same problem im at. Then he replaced the mainboard and bingo worked great
