OK I have RCA 42LA45RQ hdtv powers on, can switch inputs, volume up and down however its goes black also the screen is blue when first turns on then it says no video input(flying on screen_didnt have anything to plug into at the time) I can see the backlights coming as I have the back cover off, now from what I seen on line it more and likely the main power board( its also hold the inverter on that board too. So am I right to assume its the main power as I do notice a cap is slight discolored from the same one sitting next to it, there are only two boards in the unit main one with inputs and cpu etc and the power board. I sent a pic of the new one Im getting, if you look and right side by transformer there are 4 cap the two blues ones on top next to transformer the bottom of those two is discolored and that white connector goes too inverter board. as I stated Im hoping this is the problem.
RCA black screen
Re: RCA black screen
here are the photos
if you look at the first one you can see the discolored cap next to transformer. Being I can select inputs and control volume and menu, I don't think it's the main board.Attached Filesif you find these attachements useful please consider making a small donation to the site
i would change out those ceramic caps to start with and check your backlight transformers while your there!WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
I agree, that cap could be causing the problem. It might only be that cap but a good idea to replace all of the blue disc ones on the power board and balancer board (the white board with the other blue disc caps on it.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
how do I check that out. I do have a digital multimeter but what I don't have is a soldering iron etc. Also looking at the inverter its seems fine and all the backlights are working.Comment
The backlight typically has a 2~4 second timer, during which time it will ignore any problems. If it detects a fault it will shut down atrfter this timer expires. So you should be seeing the backlights lit for only a few seconds, or are they staying on indefinitely?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It stays on for maybe 30 seconds to a minute or more but still goes darkComment
OK, but the backlight is definitely going out? You tried plugging a source into it with a picture to make sure it's not just an aggressive energy saver? Some Vizios are known to have 5 second timers on some inputs.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
yes I plug in my directv hdmi cable and it comes on like I said for 30 seconds or more then the backlight shuts off.
its seems this is a commom problem per this website
http://www.coppelltvrepair.com/p/469...ng-off-problem
which if it is the discolored or blown cap on board I can get one a digikey since I live where the warehouse and its only 46 cents USD and I can borrow a soldering iron etc
All the other blue caps look fine even on the balance board etcComment
Well, it is handy to be that close to DigiKey, do they have a trade counter?
While you can probably get away with replacing just that cap it would be good to replace -at least- the four on the power board if not all the others on the balancer board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
not sure about trade counter, Im assuming that all the for caps on board are same 15pf 6Kv. IF not let me knowComment
Are you sure? Typically it's in very faint grey print.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I also had corrosion/oxidation on the... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared
I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
by DaniKHi everyone,
I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
Laptop came in for a SSD upgrade, took everything apart to install the SSD.
Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
Symptoms are:
- random black screen after displaying Acer logo... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
- Loading...
