I have another TV I pick up, when you turn it on, looks like everything is negative. Picture looks like a negative roll of film. As you can see from the picture. I have rule out the t-con board. This model have the inverter board and power supply built in as one. The backlight powers on fine when you turn on the tv. There are 5 inverter transformer on this board, could a bad transfomer cause the picture screen to be negative? Any thoughts?
Vizio VO370M LCD
Re: Vizio VO370M LCD
How did you rule out the tcon? This appears to be a failed Gamma Ic which usually resides on the tcon although I suppose they could have put it on the main board. Doesnt have anything to do with the inverters at all.Liberating magic smoke one part at a time -
Can we see the pictures of the T-CON board? Is it LG or AUOPTO brand? It sure looks like bad Gamma voltage to me too. Is the T-CON good for sure? There should be test points on the T-CON board to test the Gamma ref voltages.Last edited by budm; 09-27-2013, 10:08 PM.Never stop learning
What is the P/n printed on the sq IC with about 30 pin to the right of the large IC in the middle?Never stop learning
That U500 is the Gamma IC AS15.
http://assets.shopjimmy.com/media/ca...5537t05c09.jpgNever stop learning
That is very commonly failed Gamma IC, if you search the thread with "AS15" you will see lots of threads. I hope you can return the board.Never stop learning
Ok, so I order another Tcon board from ShopJimmy and install it, didn't change a thing. Problem still there, could I possible have another bad Tcon board? ShopJimmy is very reliable on their board. Could I have a bad main processor board causing this? Any thoughts?Comment
You can test the gamma voltages if you want.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Do you see the points near AS15 IC marked VG1,VG2,VG3...?
Plus VCOM, AVDD.
Test VG1...VGxxx the voltage should be monotonic (rise or fall, not both) from 0 to AVDD. VCOM should be approx 1/2 of AVDD. And AVDD should be around 14 to 18V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
