Hello, I have to buy the power adapter for Samsung LE32S86, at this link http://tv-part.com/bn44-00155a-samsung-smps-lcdtv.html, but opening up the image of me that is the BN44-00192a. Do you think the same? thanks
BN44-00192a and BN44-00155A are equal?
Re: BN44-00192a and BN44-00155A are equal?
If you jump onto the Shopjimmy website, they're showing these as subs for the BN44-00155a.
Substitute Parts:
BN44-00156A
BN44-00191A
BN44-00191B
BN44-00192A
BN44-00192B
If you goto samsung parts online it shows BN44-00192b as a direct sub which is most likely the latest revision, so I reckon you'd be safe.
http://www.samsungparts.com/Products...-00155A&model=Last edited by tw2005; 09-27-2013, 03:58 AM. -
Substitute Parts:
BN44-00156A
BN44-00191A
BN44-00191B
BN44-00192A
BN44-00192B
http://www.samsungparts.com/Products...-00155A&model=Comment
by kings crossIm trying to program a bios chip and I get this error
The bios (even the original) is 16MB but the chip is only 10MB
Any solution?-
Channel: BIOS Requests ONLY!
by HondamanRecently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
Years ago I made a "T"... -
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
by sergei66666I search bios for this model.
S\N: MP2CP9W5
MO: MPNXB2B2101F
MTM: 82SН005ЕRK
Board: Compal HLI42 LA-L961P Rev1.0
The laptop responds to the power button, the indicator next to the button starts to light, but there is no video.
The hub starts to heat up a little.
A small inspection showed that all power supplies are raised, except for VCC_CORE and VCC_GT - there is no exchange on the SVID bus between RT3624BE and the processor.
Power consumption from a laboratory power supply (when connected instead of a battery) is 13V, 370mA....-
by NormundsI tried to update bios with ch341 and normally all is good.
now it says that buffer size is not equal to ic size.
I downloaded bios and ec from msi website.
Laptop model - GS66-10sfs
mobo model - MS-16V11 ver 1.0
Programmer used: ch341
ec chip - Mxic mx 25l12872f
bios chip - winbond 25q16jvnic
Tried ch341 programmer software and other softwares. I can read and write but buffer size is not the same as chip. Looms lije file is larger than chip can handle. Maybe need to trim file...-
- Loading...
