Bios for Lеnоvо IdеаРаd 5 Рrо 14IAР7
  • sergei66666
    • Mar 2022
    • 22
    • Russia
    I search bios for this model.
    S\N: MP2CP9W5
    MO: MPNXB2B2101F
    MTM: 82SН005ЕRK
    Board: Compal HLI42 LA-L961P Rev1.0
    The laptop responds to the power button, the indicator next to the button starts to light, but there is no video.
    The hub starts to heat up a little.
    A small inspection showed that all power supplies are raised, except for VCC_CORE and VCC_GT - there is no exchange on the SVID bus between RT3624BE and the processor.
    Power consumption from a laboratory power supply (when connected instead of a battery) is 13V, 370mA.
    Perhaps the problem is in the BIOS (original image is attached).
    I tried to implant the BIOS image from the Lenovo website - it did not help (the original image is equal to the BIOS image that I got after combining the image from the website and adding DMI). I also tried to clean ME - it did not help (most likely I did something wrong).
    I would be grateful for your help.
    p.s. The laptop has already been to the repair service. I assume that some manipulations were carried out with the BIOS. But, fortunately, the DMI region remained untouched. Perhaps a cleaned dump from a working laptop will work.
  • peste
    • 13661
    • ROMANIA
    post the original bios again, the one posted cannot be downloaded..
    • sergei66666
      • Mar 2022
      • 22
      • Russia
      Done, boss!
      I also apologize for the long response (in the settings, the option to receive notifications about all events was selected, but something went wrong and I did not receive an email).
      ps Looks like there's a glitch on the forum. Many links are not working at the moment.
      pss Definitely a glitch. The attachment I just sent can't be downloaded.
      • sergei66666
        • Mar 2022
        • 22
        • Russia
        It seems the links in other topics worked. So, attempt number 3.
        • peste
          peste commented
          Editing a comment
          can't download...post the bios on another site so we can download it from there...
      • sergei66666
        • Mar 2022
        • 22
        • Russia
        Thank you. I uploaded it to Google Drive.
        https://drive.google.com/file/d/1k5e...s6a7pTF_b/view
        • sergei66666
          • Mar 2022
          • 22
          • Russia
          Got a response from the forum support with a recommendation to attach the file again - attachments should work. So attempt number 4
          ps Initially I tried to add an archive with three files (dump of the first and second flash IC and their combination) - it didn't work.
          Then I made an archive with one final file - the attachment can be downloaded successfully.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12340
            IdeaPad 5 Pro 14IAP7 - Type 82SH
            • sergei66666
              • Mar 2022
              • 22
              • Russia
              Thank you very much for your response!
              I flashed the BIOS and, to my regret, the behavior did not change - static consumption of 13V, 370mA.
              After a couple of attempts to turn on, I read the contents of the flash IC.
              The contents of the large flash IC remained unchanged.
              The contents of the small flash IC changed in two places:
              1) 72 bytes at address 0x2C2000 (beginning of block = "FCRI")
              2) 64 bytes at 0x2C3000 (beginning of block = "FCNT")
              I will continue to study the board.
              • Focus2005
                HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                by Focus2005
                Hello everyone.
                I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                05-01-2025, 05:41 AM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
                by Vesko356
                08-11-2023, 03:27 AM
              • grimacelord
                Latitude E6530 - Trouble Extracting BIOS Image From EXE
                by grimacelord
                Hi folks,
                I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
                Service tag number for this model is: "JYDWYW1".
                Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
                I have tried:
                • Simply extracting with 7zip
                • PFSExtractor
                • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
                • Check Temp folder
                10-26-2023, 08:15 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
