How do you troubleshoot this board? samsung hps4253 BN94-01081A
  • NicoNico
    • Sep 2013
    • 31
    title is wrong the board below is what i am working on
    How do I troubleshoot this board? PSU is putting out what seems to be the right voltage but relay is clicking on and off.
    BN41-00694A
    from Samsung hps4253
    Re: How do you troubleshoot this board? samsung hps4253 BN94-01081A
    A common fault with these is cold solder joints.
    First check all output voltages and PS ON signal. If PS ON is fluctuating, the main board could be bad.
    • NicoNico
      • Sep 2013
      • 31
      Thanks Tom I will try that and post results...
      • NicoNico
        • Sep 2013
        • 31
        From PSU
        VA's 65v
        VS's 200v
        Stnby 5v
        VT 33v
        From Main Board
        CN101 pin 6 fluctuating it should be 18v
        CN102 Normal
        so is this PSU problem or Main Board problem? is there a way to turn on PSU then check Voltages?
        Thanks Tom
          To check PSU, with PSON, you will need a 100 ohm ~ 470 ohm resistor, do you have one?
          • NicoNico
            • Sep 2013
            • 31
            I do
              OK, locate PSON pin (it will be labelled) on power supply connector. Unplug the connector from the main board end. Connect the PSON to ground through the resistor. Then plug power in. All voltages should rise and become stable except Vs/Va. Also the relays should only click once or twice. To test Vs/Va, unplug PSU then run a second resistor (PSON still needs jumpering) from VSON to 5V standby (not ground!) When plugged in Vs and Va should rise to appropriate levels.
              • NicoNico
                • Sep 2013
                • 31
                Ok will try that thanks again Tom
                • NicoNico
                  • Sep 2013
                  • 31
                  Connected with resistor powered on like you said and I connected the resistor to the high-voltage They check out. Can these boards be fixed? I would love to if it is doable also will be uploading video cause it turns on intermittently watch and see If it helps. I'll post it in a bit
                    So, you do not get cycling voltages or relay? Not much that can be done re main board repair. You can check voltage regulators, but that's about it.
                    • NicoNico
                      • Sep 2013
                      • 31
                      when I jump to ground PSON Relay Clicks on and stays on and voltages are there, then when I jump VSON to STBY 5v Vs are there.
                      How do I test regulators? or is there a post somewhere on how to properly test them... I have a Scope if that is easier. Thanks once again Tom
                      Nic
                      RetiredCaps posted this..
                      https://www.badcaps.net/forum/showth...est+regulators
                      7.1 Voltage regulators
                      Voltage regulators (U designation) can be bad. They can be shorted or output the incorrect voltage. The test described below only tests the former.
                      If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test voltage regulators "in circuit" for shorts by (power off and unplugged)
                      a) black on pin 1- red on pin 2 - record ohms
                      b) black on pin 1- red on pin 3 - record ohms
                      c) black on pin 2- red on pin 3 - record ohms
                      If any ohm reading is less than 30 ohm you might have shorted voltage regulator. Remove from circuit and repeat the tests to verify.
                      Last edited by NicoNico; 09-27-2013, 08:25 AM. Reason: Answered my own Question but wanted to help others
                      • NicoNico
                        • Sep 2013
                        • 31
                        http://www.youtube.com/watch?v=2WNLsJtrM7E Intermittently powers on and does this
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                          09-07-2024, 05:50 AM
                        • valvashon
                          Samsung UN65KU6290F PS board blows fuses
                          by valvashon
                          Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                          Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                          11-27-2023, 01:09 PM
                        • Asraf Atb
                          by Asraf Atb
                          01-27-2025, 05:02 PM
