Polariod FLM-2601 No picture sometimes
  • ohmmy
    • 182
    I have this polariod which original problem was no picture at all just sound.
    Took it apart and noticed two bulged caps, ESR checked all remaining and they all had high ESR so went ahead and replaced them all.
    TV now turns on and works great, however I've noticed maybe once every three times upon power up the backlights flash then turn off, if you turn set off and back on they come on and stay on fine.
    TV is a pain to take apart, lots of screws so currently it's all back together so can't provide pictures. Was wondering if this might be a capacitor problem that I missed? Only one I didn't replace was big one on primary side.
  • caphair
    • Nov 2011
    • 1249
    Re: Polariod FLM-2601 No picture sometimes
    I'm having the same issue. Replaced bulged caps and still have to power off and back on to get backlights to work 2 out of 3 times.
    Anyone know what it could be?
    • steved271
      • Jan 2014
      • 29
      • England
      Can you both get some Pictures of the Main boards and power supplies so that we can have a look and see if A: we can spot anything and B: ask you to point out a few things...
      I have fixed a few Poloroids where the Voltage Regulator for the LVDS had gone bad... but wont know until i see the board design
      • caphair
        • Nov 2011
        • 1249
        My tv is currently assembled. If I get around to it I will. This thing is a pain to disassemble.
        What were the symptoms of a bad regulator for the LVDS? Curious how you figured that out too. Thanks
        • steved271
          • Jan 2014
          • 29
          • England
          The set would intermittently lose picture when it had warmed up.... and then power down.... If i left it for about 1-2 mins it would power up again fine until warm, then start the same process....
          I tested the V Reg with the Upside down can of Air Duster as a Freeze spray when it was warm and started to be intermittent before it powered down... This made it work ok while i was spraying it but then a few mins later it would go again...
          Replaced the Voltage regulator and it worked fine....
          next time you take it apart... I know they are a pain... the poloroids all are.... If you can take pics and post, i should be able to point out the Reg that i replaced...
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
