Vizio GV47LFHDTV20A Flashing Picture and Lines on Screen Fix
  • johnboy1313
    • Nov 2012
    • 1959
    Flashing, choppy picture when source is connected
    http://www.youtube.com/watch?v=1o74xrc4amw
    And flashing lines on the screen when no source is detected.
    http://www.youtube.com/watch?v=S7KloKqgzUo
    This one turned out to be an easy fix. I suspected typical bad voltage regulators but didn't find any that measured out of spec. After the regulators checked out, I started checking voltages from the PSU. As I stuck my probe in to check the 5V leg of the PSU, I bumped the LVDS cable and the picture cleared right up. I wiggled the cable and the picture cut in and out as I wiggled. I unplugged the cable from the T-Con and used a folded piece of paper in the female connector on the board and on the pins of the male connector on the cable to remove any dirt or oxidation. I plugged it back in and was unable to get the picture to cut out when I wiggled the cable.
    Another one saved.
  • Maxstang
    • 61
    Re: Vizio GV47LFHDTV20A Flashing Picture and Lines on Screen Fix
    Awesome! Just had the same kind of fix on one of mine. I'm wondering if hot glue on the cable/connector would help this from recurring.
    • maricm
      Vizio m65-c1 picture flashing on and off on the screen
      by maricm
      HI all,
      hope someone point to the possible issue before I start buying replacement parts.
      Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
      Backlight stays on all the time,
      Sound works fine.
      screen keeps changing form black to full picture in about 1sec intervals.
      Picture looks fine with no visible artifacts.
      I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
      Disconnecting left and right ribbons on...
      11-25-2023, 06:32 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • noisykid
      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
      by noisykid
      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
      12-30-2024, 07:15 PM
    • DXseekerMO
      Vizio P502ui-B1E, delayed video, white flash, flashing picture UGH!!!
      by DXseekerMO
      About a week and a half ago this TV was traded in to me with the complaint: upon turning it on one morning a white blob slowly spread across the screen. Before I got it the TV had been sitting about 3 weeks. I also found the RF IN connector was missing. I turned it on for evaluation and got the splash screen/menus.
      I installed a 75ohm RF connector, repaired several bad grounds on the power board and chassis, checked all boards for loose screws and cleaned the entire inside of the TV. After all appeared well, the TV was tested for 40 hours and was subsequently put up for sale. ...
      05-07-2019, 07:20 PM
    • gavric
      Vizio M70-C3 Half picture is bad, main board on its last leg?
      by gavric
      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
      When tv powers on vizio V logo shows nice on whole screen. picture 1
      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
      When i click video to start playing picture goes black(like when you change...
      09-02-2021, 08:55 PM
