AcousticSolutions LCD42761F1080P dead
    Got this one in with blown mains fuse no standby.
    Vestel 17PW26-3 PSU with 17MB35-1 main board.
    Found two 7N50 FETs dead short. The 10R gate resistors measuring 35R&50R each. The FAN7711 controller IC appears OK but I will replace it too. Luckily the gate circuit is fairly simple -- nothing special. Looks like a few quid max to repair.
    This is a 1080p 100Hz motion set. Not a bad set apart from the power board. If it had some better components on the power board, it wouldn't be too bad.
    Oddly, the FAN7711 is intended for CFLs, not for the main power controller for a 42" LCD TV. They appear to modulate the RT and CT inputs to regulate the output. Rather bizarre.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: AcousticSolutions LCD42761F1080P dead
    Doesn't sound too strange - maybe the chip operates in a resonant, zvs mode? I haven't looked at the datasheet yet though.
    Muh-soggy-knee
      The driving scheme is very strange. It appears to be variable frequency variable pulse width or perhaps constant pulse width drive with variable duty cycle/frequency.
      Schematic
      It's strange to see something used to drive a 15W CFL as a controller for a 200W converter, but I guess it's 800mA gate output drive is fairly high for such a low cost chip.
      I think I'll possibly replace both FETs with 20N60s because the 7N60s are cutting it close.
        OK: Replaced both FETs, driver IC, SMD resistors, plus a diode and MLCC for charge pump.
        Turned on, 24V measures 4.9V, 12V measures 2.4V... Hmm. I listen carefully to the PSU and hear it's chirping between high and low frequency, so I go looking for shorts. So, I found a shorted diode on 24V_AUDIO line, UF5402 type. Replaced with UF5404. Turn it back on, now I get 24V at about 19V and 12V at around 8V. Still too low...
        Checked PFC voltage, getting 385V there which is fine.
        Replaced C844 (as recommended in other tips), no change in 12V/24V. Then I check the Vcc to the FAN7711 chip. It's 12.5V. The ON threshold of the IC is 11~13V, so this is very close to not working.
        I eventually found there's a transistor on the power board which switches the 18V from the standby transformer (VF_MAIN out) to the VCC1/VCC2 rail. I measured the transistor, a little BD138 PNP transistor. I found the emitter-base resistance to be 3 ohms -- not good. The emitter collector measured 500 ohms, and collector-base measured 3 ohms too. I replaced it with a TIP42C, and the 24V then hit 24.5V and the TV worked. (Vcc rose to 18V.)
        I'm guessing that the 12.8V was enough to support the IC and allow it to switch OK, but the 500 ohm resistance will have significantly reduced the pulses into the transistors. Hence the output would not have regulated properly.
        Except... I only got audio out of one channel. On the right. The left speaker was silent. I found the right channel output to be modulating fine (I got a good square wave.) But the left channel was dead. When I disconnected the speaker connections, the square wave for the left channel appeared... hmm. I found that disconnecting the tweeter for the left channel, the noise came back. So I disconnected both tweeters on both sides. Upon testing the tweeter, I could not find any short. But connecting it does cause the audio for the left to drop out. I figure that it probably has a shorted turn, inside the speaker. Very odd.
        What a crapshoot of the TV. At least it was free.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          did you do a vid of this one.
          heaps of us would love to see this repair i think!
          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            I did, but it only goes over exactly what I did in this post. I've not got my nice Samsung camera (I've lost it unfortunately) so I don't make so many videos ATM. I need to get a new one. I've made a few bucks from YouTube ads, so I'll be posting more videos soon.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              just seeing the thought process you go through to trouble shoot the problems is what i like to see.
              at least you started using a tripod, compared to your earlier vids. :P
              at least samsung cameras are better built than their tv's.
              i look forward to your future uploads of, FIX THIS DAM TV!
                Forgot to link to the video on this repair
                https://www.youtube.com/watch?v=u1gWvF1erzU
                • double_DD
                  How can I be sure that my EC chip is dead?
                  by double_DD
                  As the title suggests, how can I be sure that my EC chip is really dead?
                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                  03-12-2025, 07:47 AM
                • Lvsitano
                  Asus X532FL 3.2V at source and gate
                  by Lvsitano
                  I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                  First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                  I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                  First...
                  06-26-2024, 02:13 PM
                • disorder
                  ps5 edm-033 dead after hdmi/usb ports destroyed
                  by disorder
                  hello guys,
                  i need help to repair a edm-033 ps2
                  history : as always hdmi port and usb ports destroyed after unplugged
                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                  so i changed it
                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                  i don't see any projection of liquid metal on pcb.
                  01-14-2025, 12:48 PM
                • Beton
                  Finding a dead short component
                  by Beton
                  Hi guys!
                  I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                  So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                  I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                  I have a bench PSU and if I try to inject voltage the voltage...
                  12-10-2021, 01:05 PM
                • zunasthegreat
                  Chieftec GPS-450-AA with dead 20N60C3
                  by zunasthegreat
                  Hello everyone hope all doing well!
                  I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                  09-01-2024, 07:12 PM
