ps50c450 horizontal lines
  • wreksta
    • Aug 2013
    • 508
    • england
    I also have this come come in
    can it be fixed please
    Re: ps50c450 horizontal lines
    You need to be more descriptive but in most cases horizontal or vertical fixed lines are not repairable on LCD or plasma displays. There are a few exceptions. The B450 and C450 are notorious for horizontal lines being panel failures.
    • wreksta
      • Aug 2013
      • 508
      • england
      they are black mate and are fixed is it nothing to do with the buffer
        Single pixel line, or solid bar?
        • wreksta
          • Aug 2013
          • 508
          • england
          heres a video showing same problem
          http://www.youtube.com/watch?v=sqHwU...ature=youtu.be
          they are small horizontal lines at certain parts of the screen some in middle some at top and some nr bottom
            Panel is defective then if it looks like that
            • wreksta
              • Aug 2013
              • 508
              • england
              heres a picture showing these lines
                Reseat the panel ribbons (on y-buffer) just in case but usually it's a panel problem.
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  how t test y buffer hopefully may be that
                    You can't usually (except with a very fine probe and oscilloscope), the only way to be sure is swap the buffer.
                    Caution: Most buffers pulled from these newer cracked screen TVs are bad! (B450, C450 etc with single piece of glass panel.) Test any board before installation: http://www.youtube.com/watch?v=51SZsfH60EY
                    The above test can't be used to see if a buffer causes horizontal lines, but in 99% of cases it does not. The panel is bad almost always. It is a very common fault with these sets. If you want to try a buffer then good luck...
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • ggil44
                      Sony XBR-65X750D Horizontal lines bottom of screen
                      by ggil44
                      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                      05-30-2023, 07:51 PM
                    • noisykid
                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                      by noisykid
                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                      12-30-2024, 07:15 PM
                    • noipi
                      samsung Oled 65 Horizontal Lines and Flicker
                      by noipi
                      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                      10-14-2025, 02:11 AM
                    • x_orange90_x
                      Samsung UN46C8000XFXZA Horizontal lines
                      by x_orange90_x
                      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                      07-15-2023, 05:06 AM
