42px5d-eb no picture
    hi all
    I have here a 42px5d
    the set powers up with no picture not sure on sound as the imput wont switch to hdmi only idtv
    opened the set up up all voltages from psu are fine check out ok
    vs va etc all as it should be
    so I checked fuses on x and y board
    x fuses are fine
    y fuse isn't the one closest to the ipm is blown this is a 250v 4a fuse
    thing is I replaced it with a 250v 3a fuse but set wont turn on turnson clicks the relay then back to standby
    do you think if I put in a 4a fuse it would work I don't have one atm but will get
    Re: 42px5d-eb no picture
    Nope. The IPM is bad. Replacing the fuse has just put a short circuit across power supply. You need to replace IPM -- difficult job. Or replace Y-sus -- if you can find one.
      id prefer to replace ipm im quite good wth a soldering iron
        will replacing ipm deffinatley fix the set
        and this one isnt soldered both sides or is it
        anything else to check mate before replacing the ipm
          Quite good -- well it depends on your definition but you really need to be confident in removing a 30pin+ IC which is heatsinked on both the board and the top, and has very large heat-sucking copper traces. Yes, it is soldered both sides so you really need to suck the solder out good.
          I could not do it; one of the reasons I don't bother with these awful IPM LGs.
          If you can't do it properly, be sure not to damage the board. The sustain boards are virtually unobtainable, if you damage it beyond repair.
            bit the bullet got another ysus and buffer
            but now set refuses to turn on and I have no reading at power board
              Don't rule out your new Y-sus being bad. Test IPM for shorts from VS to GND, VS to SUS OUT and GND to SUS OUT.
                done that on ipm fuses are stil good but I have no voltages with this board in place
                  Check VS to GND on Y-sus then.
                    all voltages normal now no fuses popped but still no screen
                    how do you check buffers on these
                    or any other checks I should carry out
                      hey wrek, you need to do resistance checks on the ipm.
                      remove the board to access the legs of the ipm.
                      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                        dne that mate cheers theres no short im considering changing ipm but theres something got to be at fault on this board
                          if you have voltage at the fuse and it hasnt blown, and your ipm has checked good,
                          if this set has two buffer boards, disconnect one and see if you get half a picture.
                          some photos would be good.
                            I have 1 buffer mate I disconnected yboard from buffer can I run it like this cause I tried and heard pop cant locate nothing or smell anything
                            ill post some pics soon
                            emos tv parts have agreed to a refund but I want this working not my money bk
                              tom is it bad to test tv without buffer connected to y board
                              well turns out this board is defective but I aint got time to wait for a replacement so im going to switch ipms and hope
                                No problem without buffer connected.
                                  well I transferred the ipm and theres no shorts n it I checked but still no picture any clues
                                  I wil try swapng the other buffer in all voltages are correct from psu to ymain
                                  z main etc
                                  what am I missing
                                    What volts across any one of the bank of red poly capacitors near the IPM?
                                    Pics would help as we are working blind here.
                                      tom here some pictures
                                      which poly cap do you mean and across whats that mean grnd and then the positive on the leg or both leads on either end
                                        Across here.
                                        Putting both leads on one end would lead to a reading of zero.
                                        Put one lead on one end, one on other. Ignore negative sign on meter.
                                        If Y-sus is working, expect around 50 to 150V DC. Should match Z-sus.
