sony kdl46s4100, 66 volts at bl on with tv off
  • capkid
    • Oct 2010
    • 1339
    Re: sony kdl46s4100, 66 volts at bl on with tv off
    but I did see where other folks were having the same problem and a good av board fixed it.
    If your main board is indeed faulty, have it fixed by ModusLink PTS. This TV has all sorts of known main board issues, so you'll just end up replacing the main board again if you buy a used replacement. ModusLink charged me $70 about 6-8 months ago to repair the board for this TV.
    Edit: Sorry, I was thinking of a different TV. I bought a replacement board from TristateModule - came with a 6-month warranty. You may still want to check with ModusLink, but I don't think they repair this board. People have had success with fixes to the board performed by "koshevo" on eBay: http://www.ebay.com/itm/1-857-092-21...item4ac512d931
    LG Plasma Mal-Discharge Correction Service
    • nomoresonys
      • 12322
      • U.S.
      ok, thanks, was hoping to repair it without having to get a whole board or sending it out, but not sure where the fault lies.
      • capkid
        • Oct 2010
        • 1339
        I'm guessing a BGA is faulty on most of these boards. I don't have equipment to properly replace or reflow the chip. No more Sonys for me
        • nomoresonys
          • 12322
          • U.S.
          lol, I hear that no more for me either.
          • nomoresonys
            • 12322
            • U.S.
            I get 3.3 from bl-on with power on and connector unplugged, thats from the mainboard, and it goes to zero when powered off, but one tech said it should read 5 volts instead of 3.3 when powered on, do you think thats why the backlights stay off, he said it seems like an open resistor on the mainboard or something to that effect, thanks for any input.
              So if all the board are connected, do you get 3.3 on the bl_on pin? if you do, that means the main board is sending the correct bl_on signal. How about ps_on signal? By the way, if you pull the cable between the power supply and the main board and the backlights come on, it means the power supply/inverter are OK, but the main board keeps the BL_ON line low when they are connected, that is how you narrow down the problem to which board is bad.
              The pull-up resistor is on the power supply board instead of on the main board not like the old design, they made it that way now for easier troubleshooting which used to require using 1 k resistor between BL_ON line and 5V, same for the the PS_ON line force on using the 1k resistor.
              Signal can be from 2.5~5V.
              • nomoresonys
                • 12322
                • U.S.
                #27
                the pins on that connector read strange, the bl-dim reads 3.3v, the bl-on reads 183mv, sgnd reads 20.9mv, it strange the other two ie cn301 and cn302 read correctly and in volts not mvs. those are with all connected and power on.
                • nomoresonys
                  • 12322
                  • U.S.
                  #28
                  If I understand correctly, then the fault is in the power supply and not the main.
                  • nomoresonys
                    • 12322
                    • U.S.
                    #29
                    do you think the pull up resistor on the power supply is bad?
                    • nomoresonys
                      • 12322
                      • U.S.
                      #30
                      when I unplug cn301, I get 5.36 volts at bl-on, when I plug it back in I get 183mvs, strange, those are power on readings.
                        NO, as I indicated, when you remove the cable between the power supply and the main board then the backlights come on, then the power supply is GOOD. The pull-up resistor is ON THE POWER SUPPLY board. The transistor on the main board is in stuck on mode, that is why the BL_ON cannot go HIGH.
                        • nomoresonys
                          • 12322
                          • U.S.
                          #32
                          ok thanks, could I replace the transistor or is there a way to get it out of stuck on mode?
                            You will need the service manual to find out where the transistor is and how it is being driven.
                            • nomoresonys
                              • 12322
                              • U.S.
                              #34
                              had to get manual dvm, getting 3.22 volts from bl-on pin from av board and 5.36 from bl-on pin from ps, both readings are with boards unplugged at cn303, which is the connector for bl-on, but with the connector plugged in it reads .18 volts, isn't this weird?
                              • nomoresonys
                                • 12322
                                • U.S.
                                #35
                                could this mean that the wire connecting them could be bad?
                                • u666sa
                                  HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                  by u666sa
                                  Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                  Platform: ipa32 la-m024p rev 1b
                                  Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                  I found a short on the other side:
                                  10-04-2025, 05:03 PM
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                • Superbee_dad
                                  Sharp 80” long short flash backlight error - Help
                                  by Superbee_dad
                                  Hello Sharp TV experts
                                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                  01-24-2025, 11:51 PM
                                • dkneyle
                                  Sony KDL-46HX850 Can't upgrade/update firmware
                                  by dkneyle
                                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                  09-25-2024, 10:44 PM
                                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 05:27 AM
