Panasonic SU and SD resistance testing
  • glen65
    • Dec 2008
    • 30
    Have a Panasonic TC-P42S1.
    The SC board is definitely bad, I found several shorted components.
    I purchased another SC board, but I was unsure about the SD and SU boards.
    I didn't want to damage the new SC board. I noticed there is a resistance
    test for them in what they call the revised 2009 trouble shooting handbook.
    The SU procedure calls for unplugging SU41 and SU11, plus removing the
    floating ground screws. They then say to measure the resistance between
    the VF ground and pin 2 on the SU41 connector. The normal resistance they
    claim its supposed to be is about 2.1 meg, and a low resistance means the board
    is bad. However mine is showing high, about 12 meg instead of two. They also
    give the same 2.1 meg figure when testing the SD board. But it shows appox.
    12 meg also.
    It look as though the manual has made a mistake, but have they?
    Has anyone done this test before to confirm what the resistance is supposed to be?
    Thanks.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic SU and SD resistance testing
    ABout 2 meg would be right. My V20 is 1.89Meg. Try swapping the leads around and that you have good contact.
    • glen65
      • Dec 2008
      • 30
      I first double checked the procedure, making sure I was setting
      everything up properly prior to the test. Switched leads and
      tried a different meter. I still get the same result. Its acting as though
      something has opened up on the boards. There are several diodes on both
      boards, they checked ok.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Im a little late here but my new one tests 17 Meg, bad one tests 1 Meg. This is on a TXNSU1RJTU board.
        Liberating magic smoke one part at a time
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
        • dajoker
          Panasonic th-p50s10d - blinky red, SC board go boom
          by dajoker
          My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
          I chased my way through the PSU, and a board, with no results.
          Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
          I only have the right half of the picture.
          Left half is completely blank.
          now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
          all the other voltage rails...
          09-24-2024, 04:39 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
