Help with Samsung LN55C630 black vertical lines
  • Crazy Chuckster
    • Sep 2013
    Hello, I am looking for some help with my 3 year old Samsung LN55C630 TV. Recently it has started to display either black vertical lines or maybe its a change of resolution.
    This started popping up once every few days while watching the TV. Now this occurs every time the TV is turned on. Cold or hot, length of time on seems to have no change in how it is affected.
    If I turn it on first time for the day the lines will be there for about 5 minutes and then they go away and all is good until it is turned off again. Once that happens they appear again and last slightly longer.
    These lines also appear through any type of signal. I have my cable box which goes into the TV via HDMI, my PS3 over HDMI and I use serviio to send my movie library to the TV over the ethernet port and when the lines are on the screen they appear over any input.
    Here is a picture of what I am talking about.
    If anyone has any ideas or has seen this before I would appreciate your help!
    Re: Help with Samsung LN55C630 black vertical lines
    It is a common fault -- t-con board according to several other users with similar problems.
    • Crazy Chuckster
      • Sep 2013
      Well I will have to give that a try, thanks!
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • Firentiosi
        1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
        by Firentiosi
        Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
        The issues are as follows: the...
        11-27-2024, 12:33 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • arctor
        samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
        by arctor
        hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
        04-26-2025, 05:22 AM
      • Ancient1
        Strange LG TV issue : Image vertical lines in black screen
        by Ancient1
        Hi
        Asking for a friend.
        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
        but here its the opposite !
        TV has new T-con = same issue
        A missing panel voltage would have global effect
        So , what should one do ? how can I find where the fault is ?
        Thanks !...
        02-05-2025, 03:37 PM
