Pioneer Plasma Model# PDP-5070PU main board bad?
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Pioneer Plasma Model# PDP-5070PU main board bad?
    this is killing me anyone have any ideas? it keeps going back into lock mode and if everything is connected and i try to reset it then a red led comes on on both the power supply and the main board but shuts the power led and standby led off. but if i disconnect the hd digital assy. and try to reset it then only the red led on the main board comes on and it doesn't take it out of lock mode. any help?
      The only thing I can think is you've not connected something or perhaps ESD (electrostatic discharge) has caused a failure of the main board?
      • philliesfan30m
        • Aug 2013
        • 542
        so your saying to take all the boards out of it and take it it to my buddies house in the woods and do this to it? or do u think it is fixable? i disconnected and reconnected the connectors about 15 times and made sure each time everything was connected and in the right spot.
          I don't know; sorry.
          • philliesfan30m
            • Aug 2013
            • 542
            thanks for trying to help anyways.
            • philliesfan30m
              • Aug 2013
              • 542
              i took the board out and started testing some things but i need some help. i tested 4 n-channel mosfets on the board 2 of them were k3911 and 2 were k2698 here is what i got i don't know if i am doing it correctly i see a million different ways people check mosfets but this is the way i did it maybe i am wrong but i am trying to figure out if they are good or bad i think 1 might be bad but here are the readings.in diode mode
              k3911 readings
              -lead +lead
              g-d OL both
              g-s 1530 both
              d-s 474 both
              +lead -lead
              g-d OL both
              g-s 1690 both
              d-s OL both
              k2698 readings
              -lead +lead
              g-d OL both
              g-s 780 both
              d-s 510 both
              +lead -lead
              g-d OL for 1 mosfet and other reads 760 and climbs up
              g-s OL both
              d-s OL both
              the 1 that climbs up is the 1 i am guessing is bad and they were all tested in circuit. should i take the 1 that climbs up out of the board and recheck? or do they all need to be taken out? all help appreciated
              • philliesfan30m
                • Aug 2013
                • 542
                when i checked the bottom of the board it looks like str-f6167 got hot which is a switching regulator but i don't know how to check it to see if it is bad. and i can't find a cross reference for it. no one in the US even sells them that i saw.
                • philliesfan30m
                  • Aug 2013
                  • 542
                  can someone tell me what on the power supply sends the voltage to the vsus and vadr connectors? i don't have any power to those connectors but i do have power to every other connector on the board.
                  • philliesfan30m
                    • Aug 2013
                    • 542
                    i am only getting 180v across the 450v caps but i don't know why? can someone help me out?
                    • philliesfan30m
                      • Aug 2013
                      • 542
                      if i'm getting the correct voltage there then why am i not getting the 60v at the vsus and vadr connectors?
                        That will be caused by the PFC circuit not working. Which can be caused by a number of factors, one of them is the main board not telling PFC to turn on, the other is a fault on the PFC circuit.
                        • philliesfan30m
                          • Aug 2013
                          • 542
                          well how can i tell what all is on that circuit so i can narrow it down? or how would i be able to tell if the main board is sending the signal to turn it on?
                            A signal such as POWER ON, PS ON, ON/OFF... from main board to power board.
                            • philliesfan30m
                              • Aug 2013
                              • 542
                              there isn't any of those from the connector going to the main board from the power supply. i can name all of them on the board that go to the main board but they aren't labeled like that or even close. all the voltages from the power board to the main board and vice versa are all the marked voltages they are suppose to be so then i am guessing it is sending the signal.
                                Is there a pin diagram in the service manual?
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  yes on page 68 p8 and p9 connect to the main board if that is what you mean
                                  • philliesfan30m
                                    • Aug 2013
                                    • 542
                                    is that what you meant?
                                      M_SW_DET, U_SW and AC_DET, what do you get, DC volts?
                                      • philliesfan30m
                                        • Aug 2013
                                        • 542
                                        M_SW_DET 3.16v
                                        AC_DET 2.91v
                                        U_SW 2.17
                                        • philliesfan30m
                                          • Aug 2013
                                          • 542
                                          the 3rd pin on that connector says N.C. (relay) what does the n.c. stand for and what does it do? that one i don't have any reading on but it says i should have about 3.5v. is that a problem?
                                          • bffargo
                                            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                            by bffargo
                                            LG 60PB66550 NOV 2014
                                            PSU: EAY63168603
                                            PCB: EAX65359531 2013.11.01 Rev:1.0
                                            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                            Symptom:
                                            While watching, just went black and started clicking relay every few seconds.
                                            Initial diagnosis:
                                            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                            Deeper diagnosis:
                                            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                            09-09-2022, 07:34 PM
                                          • pixelcap
                                            Pioneer Plasma 111FD To Solder or Not to Solder.
                                            by pixelcap
                                            Hello out there in Badcap land.
                                            I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
                                            are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
                                            Thank you
                                            Pixelcap...
                                            03-08-2025, 07:10 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • bcstedt
                                            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                            by bcstedt
                                            Just starting to crack into this one and wanted to get the ball rolling.
                                            At power on (plug in), power light on, relays click, repeat (sometimes)
                                            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                            Removed Y-Main for inspection and testing
                                            This pic from:
                                            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                            12-15-2023, 10:30 AM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
