PN42A400C2D issue
+ More Options
Posts
    Re: PN42A400C2D issue
    Well, it may be fine. But it is very hard to test them.
    • CLANKIRKPATRICK
      • Sep 2013
      • 26
      Just wanted to give an update and thanks...I switched out the Y-main and Y-buffer and it now works perfectly...Thank you a million times over Tom and capkid!
      • capkid
        • Oct 2010
        • 1339
        Good news. Glad to help.
        LG Plasma Mal-Discharge Correction Service
          Great! Enjoy your TV.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
          • Simone Vergani
            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
            by Simone Vergani
            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
            To assist with troubleshooting, I'm attaching two power circuit schematics:
            • Power
            03-05-2025, 02:25 PM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
