toshiba pdp50x3 power supply issue
  • joe904
    • Aug 2013
    • 27
    • usa
    Re: toshiba pdp50x3 power supply issue
    I have noticed if I disconnect the av from the psu voltage stays constant and does not click off. I also just disconnected scaler board only still voltage drop in va and vs resulting in clicking off then trys to restart. can av board cause this?
      Not typically, but it's plausible that the software/EEPROM on it got corrupted by all the power cycles leaving it in an inbetween / inconsistent state.
      • joe904
        • Aug 2013
        • 27
        • usa
        any suggestions i'm at a loss is their any thing I can check before replacement.
          You can check things like the voltage regulators, and the AC DET signal from PSU. Try with Z-sus and Y-sus unplugged too. Other than that, I'm really not sure.
          • joe904
            • Aug 2013
            • 27
            • usa
            last thing .. I unplugged scaler from av remained on my its scaler board I have no clue thanks for all the help
            • joe904
              • Aug 2013
              • 27
              • usa
              #26
              I guess i'll try to figure this out again ; the set when plugged in trys to power on. front panel light is green . logic board d15 lites up d18 lites up d1 lites up d2 lites up then clicks and shuts down . then 10 seconds starts the cycle again. i have found that if I disconnect the plug from psu to the av board it does not shut down . if I only unplug from logic to scaler board .still clicks off. can an av board cause this problem???
              • joe904
                • Aug 2013
                • 27
                • usa
                #27
                I have figured it out . it was the scaler board it was shutting down power supply. thanks for the help . its up and working great.
                • Soulzink
                  Samsug washing machine. Power supply DC41-00189a board issue
                  by Soulzink
                  I am trying to fix a samsung washinmachine power supply main board.
                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                  The power supply board reference is the following: DC41-00189a
                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                  04-19-2025, 06:26 AM
                • semiRocket
                  Toshiba 37bv701b power supply main rails
                  by semiRocket
                  The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                  I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                  Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                  10-26-2025, 01:55 AM
                  09-06-2024, 05:27 AM
                • KYBOSH
                  Eufy Floodlight Cam 2 Pro Dead. Power Supply issue...
                  by KYBOSH
                  I have a floodlight-security camera that recently died on me.
                  its hardwired to 115v po115v outlet. One evening it simply died. After some troubleshooting (ensuring it had power and ensuring the electronics were actually functional by supplying 5v via usb port) i realized the power supply must be the issue. The supply was noticably warm to the touch even though it was not powering anything.
                  Trying to understand what i was up against i went looking for others with similar issues and anyone who might have attempted a repair. While a few ppl have had the...
                  07-01-2024, 06:54 AM
