RCA 32V432T Possibly Bad Fly-Back Transformer?
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #41
    Re: RCA 32V432T Possibly Bad Fly-Back Transformer?
    Originally posted by Mrx3750
    Oh yeah you're on the right track.
    Are you sure the TV is getting a 4:3 signal? That looks like a 16:9 image, and I don't see squashing.
    As for the crooked screen, that lies in the yoke position, and with it being an RCA, the yoke is likely bonded to the CRT.
    Good call on the 4:3, I thought that was it at first. It's not though. A new discovery though. When I hit guide on the cable box, the screen on the RCA is full screen. When I exit it, it's back to missing the 2 inches at the top and the 2 inches at the bottom. We have the cable box plugged into our main television set, which is a plasma HD 50" wide screen. It's plugged in via HDMI cable. On the RCA, we plug RCA cables from the back of the cable box into the RCA TV. I switched the settings on the cable box to 4:3 and I set it to normal, not stretched, and I set it to standard def, not Auto HD.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      #42
      I think it's fixed. On the cable box, if it's on a channel that's displayed in 480i, it shows full screen. If it's a channel that shows 1080i, it's squished. I think we got this one guys! I'm going to start putting it back together I do believe, and I will be giving it to my mother. Thank you so much, I'm sure she'll have me thank you guys as well. I could not of done it without you guys! Thanks.
      • Mrx3750
        • Jul 2013
        • 311
        Oh yeah it's fixed. If you get *any* display at full screen, the vertical's doing its thing just fine.
        Only other thing I'd do is run the TV for a few hours just to make sure everything behaves itself.
        • Spork Schivago
          • Mar 2012
          • 4734
          #44
          You guys freaking rock!!!!!!!!!!! I'm trying to adjust the settings now, like brightness and colour but I'm not very good at it. I got a friend trying to match it to the picture on the Plasma. Isn't working very good though.
          With Plasmas, someone told me you need to get them charged every so many years. Is that true? Our black isn't working right. When I had the computer hooked up to it on the HDMI 3 port (the one for the computer), and I had a black box up on the screen, part of it was gray, part was black...
          Last edited by Spork Schivago; 08-30-2013, 07:10 PM. Reason: gramatical correction
          • Mrx3750
            • Jul 2013
            • 311
            To properly adjust the RCA TV, you're going to need a DVD player and a test pattern DVD. You *will not* get it looking as good as your plasma. It's just not built for that. However if you must play with the settings to get the best image you can out of it, see about downloading a test pattern DVD ISO.
            This should work for you.
            http://techpreservation.dyndns.org/dvddl/testdisc.htm
            Also should be good for calibrating HD displays should you feel the need to. For your RCA, I'd just worry about making sure it displays red, green, and blue uniformly, and check the grayscale. (find the pattern that shows many shades of gray and adjust brightness/contrast until you can see them all, and the color black looks, well, black.)
            This image is the grayscale test pattern: http://techpreservation.dyndns.org/B...DEO_CTP3_7.jpg
            • Spork Schivago
              • Mar 2012
              • 4734
              #46
              ... This should work for you.
              Thank you for the link, however, I cannot play that in my DVD player. Nor can I play it on the computer. It's a different region and my DVD player is not hacked. It's not a region-free DVD player either. It's locked to our region, region 1 (USA). Any suggestions?
              • Spork Schivago
                • Mar 2012
                • 4734
                #47
                Actually, I got a couple ideas. I'm real good at computers. I burned it on CD. Gonna try burning it on DVD and if it doesn't work, I'll just rip it and burn a region free copy. It's been a long day and I'm kind of tired, not thinking right. Thanks for the links!
                • Mrx3750
                  • Jul 2013
                  • 311
                  Should work, but it has to be burned to a DVD.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #49
                    Yeah, when I burned it on DVD it worked. Any idea what TINT means on the TV menu? It's hard for me to use the colour ones because I don't really have anything to compare the blue's and green's and red's too. I tried using the computer and when I thought it was matched up, colour was all the way up to 100. When I flipped it to a TV channel, it was terrible looking.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #50
                      I almost got it but the white isn't bright enough and orange looks too red.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #51
                        I think I got the colour fixed. It just doesn't have that glow like the plasma has. Is that because it's a CRT? Like the white not being bright white like it is on the plasma?
                        • Mrx3750
                          • Jul 2013
                          • 311
                          First off comparing it to Plasma is not a good idea, because they're two different beasts and they work very differently.
                          Really you would compare it to a known working CRT display, but even then as CRT's vary so widely even among the same brand, you won't get perfect matching displays.
                          Step 1 is to factory reset the TV (should be a menu option)
                          Step 2 is to load the grayscale image and see if you can pick out all the color shades, including the stripes in the middle. Adjust brightness and contrast until you can while making sure that black is still black.
                          Step 3 is to display the pure red, pure green, and pure blue. The colors won't look like they do on your plasma, but as long as they look red, green, and blue this means your color guns are doing their thing.
                          Next there should be color images somewhere on that DVD. Just make sure they look roughly like the example images do on the website (colors match more or less. It doesn't have to be perfect and you will drive yourself insane if you try to make it perfect)
                          Now you're likely going to see imperfections in the image. It may be bowed slightly, or the corners might be a bit "fuzzy" while the center of the image is clear. This is normal, and I find that most people don't give a flip about minor distortions or imperfections so long as the thing displays a picture.
                            Complete bullshit, not a lick of truth... you never have to "charge up" a plasma display. If the black level isn't great, you may get a better picture by tweaking the priming voltages and timings, which can be done by opening the set.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #54
                              Okay, I've done what you said and you were right about the fuzziness. My mother loves the TV and says the colours a lot better than the old one. So I think I was successful in changing the settings. Thank you so much for explaining that. And thanks for the help.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #55
                                Thank you so much! He was the guy that told me the flyback was bad. Turns out it was just a couple caps and a bad diode. When I get some time, I'll look into tweaking the priming voltages and timings. I'm working on her old set now. It has no on screen display. I'm trying to find the service manual. It's a CT-36D30B. I had a couple a while ago but lost it. I'm going to try fixing this one with little to no help. I'm going to see if I've learned anything. I have a feeling it's a bad IC. I'll check the voltages once I get the service manual again. Wish me luck!
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #56
                                  I found a site where I can buy it for 16$ and download it. Do you guys think it's worth it?
                                    Nope. Lemme see if I still have access to Panasonic's service site in China, I may be able to get you it. If it was released in China or Taiwan.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #58
                                      Thank you, I created a new thread for this because I thought it'd give me better results.
                                        Unfortunately it's no longer available. I can ask a friend of mine if he has access to it, but he probably doesn't because it's an older CRT.
                                        • Spork Schivago
                                          • Mar 2012
                                          • 4734
                                          #60
                                          Well thank you for trying. I don't know how much good I can do without the service manual but maybe I'll take a peek and see what I can see.
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • pni
                                            LG 49uf695v vertical coloured lines
                                            by pni
                                            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                            11-14-2025, 03:15 AM
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                          • visionbluedemon
                                            Help. Sony kd-65x85dj vertical lines
                                            by visionbluedemon
                                            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                            tried blocking LC lines too, but same results
                                            is it lcd panel issue or tcon board issue?...
                                            07-25-2025, 04:56 AM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
