Magnavox 42MF438B/27 - either shuts off completely or loses picture but keeps sound
  • Joshster
    • Aug 2013
    • 12
    Magnavox 42MF438B/27, Chassis LC8.1U LA
    The TV will come on and I can watch for anywhere from 5-30 minutes before either powering off completely, or losing the picture only (sound will still play). I would then unplug it and it would do the same thing after restarting. Usually, after the second time unplugging it and restarting, it would stay on. Leaving it unplugged overnight seemed to allow it to stay on longer.
    I replaced all 22 cylinder shaped capacitors (although none showed obvious signs of failure) on the power supply board, but the problem remains. It actually seems to shut off or lose picture faster than before. When the picture disappeared but I still had sound, I was able to see the menu items when I held a flashlight up to the screen.
    Just to be clear: The TV does both randomly and continually - either shuts off completely OR loses picture but keeps sound.
    I am not at all experienced in electronics but willing to learn and try to fix this TV if possible and not too expensive.
    Any guidance is much appreciated.
  • Joshster
    • Aug 2013
    • 12
    Re: Magnavox 42MF438B/27 - either shuts off completely or loses picture but keeps sou
    Forgot to add pics to original post.
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Inverter boards??
      Checked any regulators on the main??
        Since this is power supply/inverter combo board, there should be a pin labeled with INV_ON, or BL_ON on one of the, see if it changes state when the backlights go out.
        • Joshster
          • Aug 2013
          • 12
          Ok thank you for the replies. I will try to test the inverter boards today. Is this something I can do with a basic $50 multimeter? Like I said, I'm very inexperienced with electronics...don't want to break anything or get fried. Thanks.
          • Joshster
            • Aug 2013
            • 12
            I found the pin labeled INV_on and measured with my multimeter. It measured the same whether the screen was lit or not (3.244 V). On the SSB, I noticed two green LED lights. They both stay on even after the backlights go out. Not sure if that is relevant, just thought I would mention it.
            I took measurements of all the pins just in case (power was on but the backlights went out):
            CN6
            3V3 ST = 3.313 V
            standby = 15.6 mV
            GND = -1.7 mV
            GND = -1.7 mV
            GND = -1.7 mV
            12 V ssb = 12.04 V
            12 V ssb = 12.04 V
            12 V ssb = 12.04 V
            +12V aud = 13.4 V
            GND_aud = 1.0 mV
            -12V aud = -13.2 V
            CN7
            12V ssb = 12.04 V
            12V ssb = 12.04 V
            GND = -1.2 mV
            GND = -1.2 mV
            INV_on = 3.244 V
            DIM = 1.802 V
            boost = 1.488 V
            GND = -1.4 mV
            Awaiting further instruction, thank you.
              The INV_ON/OFF should change state when the TV is toggle on and off, it sounds like the main board is the problem.
              • Joshster
                • Aug 2013
                • 12
                budm,
                The INV_on measures 3.244 as long as the power light is on. The voltage doesn't change regardless of the screen's backlights being on or off, as long as the TV is getting power. When I press the power button to turn the TV completely off, it drops to 0 V.
                Is the main board something I can fix or will it have to be replaced?
                Thank you!
                • Joshster
                  • Aug 2013
                  • 12
                  Suggestions, anyone? Kids really miss their TV...
                  • Joshster
                    • Aug 2013
                    • 12
                    FIXED! I went back and touched up the solders on a handful of the replaced caps. TV has been good for 2 weeks now.
                    • Joshster
                      • Aug 2013
                      • 12
                      UPDATE
                      OK, so after nearly a year working well, this TV has developed a problem similar to the original. It doesn't power off completely, but the picture goes black while the sound stays on. This is usually accompanied by a burning smell and the back of the TV feels hot. Thinking it may be low quality capacitors used in the first repair, I pulled the back off the TV and noticed no obviously bad caps. However, the Power Supply Board has an obviously burned spot on the large component just beneath the CN2 and CN3 connectors.
                      I have no idea what this piece is. Can this be fixed, and if so, can I just simply replace this piece?
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        looks to me that solder joint is really bad....Might just have to resolder that joint,but make sure you use lots of solder,I would almost take a thicker gauge wire and lay it on that trace,so you can solder that wire to that joint but also a bit away from the burned spot...
                        Proud owner of dozens of broken TV's and many,many,many boards.
                        Our website and passion:http://hollenhundshepherds.com/
                        • Joshster
                          • Aug 2013
                          • 12
                          Thanks Martino. So you think the solder joint was loose and that's what caused it to burn? No need to replace whatever that piece is?
                            "The INV_ON/OFF should change state when the TV is toggle on and off, it sounds like the main board is the problem."
                            "The INV_on measures 3.244 as long as the power light is on. The voltage doesn't change regardless of the screen's backlights being on or off, as long as the TV is getting power. When I press the power button to turn the TV completely off, it drops to 0 V." That is normal and glad you found the problem, that is one reason it is important we we get the correct info when the TV is ON and when the TV is OFF.
                            BTW, that bad joint on the primary side of the inverter transformer had lot spark due to about 400V switching DC is applied and enough to cause black marking on the board, I would remove the old solder and clean that section real well then use good flux and solder on the joints, might as well do the same on the other pins as well, and inspect the whole board.
                            • Joshster
                              • Aug 2013
                              • 12
                              Thanks all. Followed your advice and seems to be working fine again.
                              • tonybig10
                                Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                by tonybig10
                                Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                03-07-2025, 01:03 PM
                              • falcontech
                                Denon Mc6000 channel 1 completely non-functional
                                by falcontech
                                Hello
                                I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
                                09-04-2025, 09:03 AM
                              • max-power
                                Dell E6540 laptop completely dead after dssasembly
                                by max-power
                                Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                03-24-2025, 08:49 AM
                              • fiveseventy
                                RX570 dies completely, then recovers.
                                by fiveseventy
                                Hello all,
                                I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
                                The card was bought used maybe 5 years ago and has worked without issue until recently.
                                I have no reason to believe it has been worked on or physically damaged.
                                For periods of time it will be 100% perfect.
                                Perfect temperatures, no glitches or artefacts, solid FPS.
                                I can game, run benchmarks, do whatever without any problem.
                                I can reboot the machine as many times as I like and nothing changes
                                however, most times...
                                06-22-2024, 05:29 AM
                              • pavski
                                Completely dead MSI z490 tomahawk
                                by pavski
                                Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                Can you please let me know if this is indeed incorrect and what else should I look at next?
                                Thanks!
                                06-02-2024, 02:42 PM
