Lg pc503d ps problems
  • NasTech
    • Sep 2011
    • 58
    I follow the post with PC503D issues
    The Problem am having is the tv when the power button is press the front led goes from red, green then back red. It startups ones then shutsdown. The voltages i read on P800 Connector
    Press Power Stutsdown
    P800 PINS
    4.83v 1. AC-D 4.85V
    4.53V 2. RL-ON 0V
    5.03 3. STANDBY 5.04V
    3.6V 5. VS-ON 0V
    4.66V 6. 5V-D 0V
    5.02V 7. M5V-ON 0V
    5.03V 8. STANDBY 5.05V
    3.32V 10. NC 3.34V
    5.98V 11. 6V 0V
    4.53V 13. 3.3V 0V
    The Connector P802/P803 Voltages startup then stutsdown.
    But i'll disconnect y-sus cables from PS the voltages Vs-230v then drop fast and stay at 4v, Va-66v then drop fast to 0v but the 5v-4.98 and stays there.
    Next I disconnected P800 from the main Board jump 470 resistors from standby to rl-on and m5-on PS voltages reading 6v-6v, 12v-12v, 19v-19v, 3.3v-0v, Vs-0v,Va-0v and 5v-5v
    Disconnected P804 & P805 voltages reading 6v-6v, 12v-10v, 19v-17v, 3.3v-0v, Vs-0v,Va-0v and 5v-5v
    jump 470 resistors from standby to rl-on, m5-on and vs-on PS shutsdowns
    Feel the problem is in the Vs &Va Section of PS But Any direction to solve this problem welcome
    Patrick
  • jean luc ferre
    laptop hp g72 b52sf screen problems
    by jean luc ferre
    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
    06-07-2025, 03:27 PM
  • Hondaman
    USB problems?
    by Hondaman
    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
    08-12-2024, 03:26 PM
  • clabr
    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
    by clabr
    Need help to solve some problems with this laptop.
    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
    Before this had happened I observed some other problems:
    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
    12-02-2021, 08:09 AM
  • jean luc ferre
    display screen problems after changing motherboard
    by jean luc ferre
    First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
    I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
    Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
    Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
    09-11-2025, 10:28 AM
  • rumpumpel1
    Lenovo X13-Yoga Gen 1: hibernation problems
    by rumpumpel1
    I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
    11-03-2024, 12:31 AM
